Question about Pro-Fit Pro.Fit Cd 55 98 Cadillac Seville Sls/Sts 98 Up
I own a Cadillac Seville STS, on my dash it reads refridgerant very low , and also it says A.C compresser off. I just refilled my coolant with refridgerant with the r142a and it did not work.The dash still reads refridgerant very low and A.C comprsser shut off. It is burning hot and I need any help I can get
  • Anonymous Mar 25, 2014
    The low fuel alarm is not sounding either
    Top Expert:
  • Pro-Fit Master
  • 79,865 Answers
U have a leak in the ac suystem, u will have to have the system leak tested and the leak repaired before adding anymore very expensive R134 refridgerent.
Posted on Jul 02, 2009
Is 225 an acceptable operating coolant temperature for a 1993 Cadillac Seville STS 4.6L ?
225 F equates to 107.22 Celcius
normal operating range for engines is 85 c(185F) to 98 C (208 F)
100 C is boiling so 212 F is maximum temp anything over is excessive and requires attention
Nov 06, 2016 | 1993 Cadillac Seville
Turn signal flasher on a cadillac seville sts 1994
  1. The flasher is hidden under the left (drivers) side of the dash, in the vicinity of the steering column.
Dec 30, 2012 | Cars & Trucks
Just changed oil and filter on my 96 cadillac seville sts and the dash still reads 0% oil life. why?
You need to rest the monitor. It does not do this automatically. Turn the key on, do not start the vehicle. Press the gas pedal all the way to the floor three times turn the key off and then start the car. It should now read 100%. The owners manual will have this info as well.
Aug 05, 2012 | Cadillac Seville Cars & Trucks
02 cadillac seville sts keeps loosing coolant ,no signs of leaks anywere
Did your car over heat at any time if so check the Oil if it looks muddy or like cholic milk it has a warped, or cracket head or a blowen head gasket...........Hope tis is not the case and good luck
Dec 01, 2010 | 2002 Cadillac Seville
99 cadillac STS, the coolant is not circulating through the engine good. you can hear the air in it when you drive. it sounds like gurgeling. the heat gets hot then cold then luke warm then hot again. the...
take it to a radiator shop and have it done properly
suggest you have a compression test done as it may be compression gas in the cooling system
Oct 13, 2017 | 1999 Cadillac Seville
Car won't start
Sounds like it is burning coolant, possible blown head gasket or cracked head or intake leak.
If too much coolant enters the cylinder it will stop the engine from running.
Sep 29, 2009 | 1999 Cadillac Seville
MY 1997 CADILLAC STS DASH READS A\C LOW COMPRESSOR OFF
if its saying a/c the freon is more than likly low, check same, clear the error by add freon
Jul 21, 2009 | 1997 Cadillac Seville
A.C compressor reads off on my dash. Also I refilled my refriderant and it didnt work. I own A 97 Cadillac Seville STS.
If it builds up too much pressure in the system it will shut off compressor. May be an AC pressure switch problem if compressor does not even come on.
Jul 02, 2009 | Cadillac Seville Cars & Trucks
I own a Cadillac Seville STS, on my dash it reads refridgerant very low , and also it says A.C compresser off. I just refilled my coolant with refridgerant with the r142a and it did not work.The dash still...
You have a leak in the ac system, u will have to have the system leak tested and the leak repaired before adding anymore very expensive R134 refridgerent.
Jul 02, 2009 | Cadillac STS Cars & Trucks
Pro-Fit Pro.Fit Cd 55 98 Cadillac Seville Sls/Sts 98 Up Logo
231 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
