Question about Ruud Matching Split Air Conditioner
Fan not turning - Ruud Matching Split Air Conditioner
  • 121 Answers
Check fan capacitor,disconnect capacitor and measure it with ohm meter,put value on ohm meter ohm x100 or more,measure capacitor
it must show some value but it will be very fast,if there is no value change a capacitor,a new must have same parameters(values) as old
e.g. 80 micro F,220(110,380)V.Note a wire which was on capacitor.
If not capacitor,check fan motor,also with ohm meter,measure all wire for each other,ohm meter must show some value,e.g. 25 ohm.
DISCONNECT air conditioner FROM ELECTRIC POWER WHEN YOU WORK THIS,AND BEFORE MEASURING CAPACITOR SHORT CUT IT WITH A ISOLATED SCREWDRIVER!
Posted on Jul 02, 2009
Fan barely turns
If the fan is barely turning, it could be the fan is bad. This fan blows air across a 2 coils.
May 29, 2014 | Haier HD456 Dehumidifier
2003 ram 3.7 l overheating. Water pump, thermostat, coolant are new but still overheating
Check for possible air flow restriction to the radiatior. Anything stuck in the cooling fins to cause a blockage. Also check the cooling fan to see if it is working properly. To check the fan (while engine is cold) turn the blades on fan, if the blades do not turn freely then the fan is at fault.Grasp the fan on both sides and rock the fan checking for any excessive bearing play (wobble). To check the fan after the truck has warmed up, turn the ignition off andd disconnect negative wire from battery. Turn the fan by hand, some resistance should be felt. If the fan turnes easily, replace the fan. Hope this will help you.
May 31, 2010 | 2004 Dodge Ram
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
My coolant is not working? when driveing it stays cool but as soon as i stop the fan dosnot kick in ad i over heat?
The coolant is working well, because the engine stays cool while driving. The problem is the fan relay, fuse, or the fan itself. Do you have AC? If so, turn it on and you should have instant running of the fan. The normal operation of the fan is: the engine thermal sensor tells the computer that it is getting hot which in turn tells the fan relay to turn on and that is supposed to turn on the fan itself. The fuse protects the high current wire to the fan. Try to turn the fan blades by hand--if stuck or very hard to turn, replace the fan motor. If you can't find the fan relay in the fuse compartment, it may be a solid-state device that is located near the fan motor. Chase the fan wiring back to the relay. Hope this helps!
Apr 30, 2010 | 1999 Jeep Grand Cherokee
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Rad fan makes car shake 2003 sunfire
I would check the radiator fan in the car for looseness. If the fan wobbles or moves , Then change out the radiator fan. The radiator fan and motor come as one piece. There is a fan relay also should be replaced.
When turning the key only half way to make the dash fan work, indicates that the dash fan is okay.
The dash fan may make a whining or high pitch noise when engage. Then I would change it out because an internal bearing to the fan is going out.
Good luck
Mar 18, 2009 | 2003 Pontiac Sunfire
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Ruud Matching Split Air Conditioner Logo
172 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
