Question about NetGear SUPER-G WGT624 Wireless Router (WGT624NA)
Need to reconfigure router to new modem after moving and getting a new internet service and modem HELP
  • 477 Answers
Hello, you need the settings from your new service provider. do you have them? usually its just plug and play. the router should be configured as DHCP to your service provider (WAN). but you need the exact settings.
Posted on Jul 02, 2009
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Orange web light\
this means the modem has lost the username and pw. u need to speak to ur internet service provider to get them and they can help u reconfigure the modem if u dnt know how. goodluck
Nov 27, 2013 | D-Link Dir-601 Wireless Broadband Router -...
Moved router to another location would not connect.
Who is your Internet service provider at new location?
I think you should try to reset and reconfigure the router from the scratch.
Connect the computer directly to the modem and make sure that your Internet modem is working properly.
Connect the modem and computer to the router. Open the setup page of the router and change the settings of the router.
You can try this Linksys Router Setup website and I think it will help you.
May 27, 2012 | Linksys Wireless-G WRT54G Router
I have just moved my business to a new location. I got here and plugged everything in the same way, but my wireless computers are picking up my network but can't connect to the internet.
The problem is not the router or Wifi system, but the configuration for the modem connecting to the Internet at your new location vs. the old location.
I would call the tech support of the Internet Service Provider to solve this problem. Your Cable Modem or DSL modem will have to be reconfigured for the new location.
Good luck on this new installation.
Jan 31, 2011 | Computers & Internet
New modem & nowI cannot acces the internet or email. I got a new
Reset your router and reconfigure your router as per the new modem settings or else you can contact your isp after the router reset.
Jun 03, 2010 | Linksys Wireless-G WRT54G Router
Router doesn't work since moving.
That is a question for you to pose to your new service provider.
Sep 09, 2017 | Microsoft Broadband Networking MN-100...
Need to reconfigure router due to installing a new modem.
use the route back address to approach your router.
this will take you to router settings.
Sep 29, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
The network is working but I can't get the internet
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
Aug 12, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
New modem now router doesn't work
you need to make sure that you can access the internet from your new modem first. if you can't access the internet, you need to call your ISP. but if you can access the internet properly using your modem, you need to reconfigure your router by running the setup cd to recognize the new modem.
hope this'll help you but if you still have problems, just provide the brand and model of your new modem and your router and your ISP as well.
ciao!
Aug 10, 2008 | Dynex 4-Port Ethernet Broadband Router...
NetGear SUPER-G WGT624 Wireless Router (WGT624NA) Logo
79 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
