Question about Xerox Phaser 8500/DN Printer
Service error 37,003.48
Getting error service 37,003.48. What does it mean?
fossilruins
  • 114 Answers
SOURCE: Xerox Phaser 8400 getting error -- Service Needed 37,002.47:72864
The technical error message means:
The Printhead Left jetstack heater is not drawing the expected power from the power supply.
Possible solutions:
1) Make sure the AC plug is plugged into the wall and not a UPS or surge protector. Other things such as another printer, coffee maker or other electrical devices on the same circuit could cause a sag in AC demand from the Phaser, causing it to fail it's PEST (Print Engine Self Test).
2) Verify that the wall outlet's circuit is capable of delivering the correct amount of current to the Phaser, if it does, check how many other electrical devices (aka a desklamp, radio, etc.) are on the circuit.
3) If it's out of warranty, reseat the cables from the Printhead to the Electronics Module. If it's in warranty, place a service call on the unit.
Posted on Jun 09, 2008
SOURCE: Call Service F000 error
i solve it by turn off the printer and later on after one minute turn on again, it works perfectly.
Posted on Sep 12, 2008
A3sthetix
  • 41 Answers
SOURCE: 939 service system board; what it's mean.
First, make sure the printer power is off and remove the RIP board. When you turn the printer back on, the only option on the display will be to perform the test. Pressing the button next to that begins the test. The page that comes out should have just a lot of lines printed on it. If this does not print or is somehow messed up, then the problem must be with the engine board. If this page prints and looks OK, then it is probably the RIP board that should be replaced. Please keep in mind that this test cannot be considered to be conclusive but it can be used to make an educated guess about which component is failing.
When the printer beeps five times and the operator panel is blank, there are several things that might cause this. It could be the op panel, the op panel cable, the Low Voltage Power Supply (LVPS), or the engine board. To find out which component is failing, the printer would need to be checked out by a service technician and the failing component replaced by him/her.
Posted on Jul 13, 2009
  • 123 Answers
SOURCE: Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
Posted on Apr 26, 2010
  • 7 Answers
SOURCE: we keep getting an error message - service error
Have you replaced the inks friend had same problem ink was'nt seated right took them out and refitted them error vanished.
Posted on May 24, 2010
Need info to fix error
Are you sure it's 1300 service code as I have the service manual and that code is not listed
Sep 03, 2014 | Kyocera FS-9130DN Laser Printer
What does trouble code C-1292 mean on a konica minota C7000
some research online suggests 'stack oveflow, and possible need of drum replacement. try site 'error 1292 in mysql' good luck!!
Mar 27, 2014 | Konica Minolta bizhub Office Equipment &...
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 29, 2012 | Water Heaters
Muratec F-320 Super G3 we are getting a fax ready Please call Service message
Please Call Service means the machine "thinks" it has detected a fault.
To check do the following..
Press PROGRAM,*, 6
Then press PROGRAM to select Service Call mode, then press ENTER....the error message will be displayed in the display.
Most common error given machine age was "Heater Error".
If this is the case you will need a Serviceman to do repairs to the Fuser Unit.
Oct 25, 2010 | Muratec F320 Plain Paper LED Fax
Getting error code e000748-4000
E744, means that Language file/BootROM error.
You need to upgrade the DC controller PCB version, wich is done over service support tool. That means that you cant do it on your own, call service.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER C3170U Color Copier
Epson 3800 won't work
you cant fix it of your own better to visit service centre.
this error require counter reset through software
Jun 10, 2009 | Epson Stylus Pro 3800 InkJet Printer
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
I keep getting the error "E1" & the dryer turns off ...what does that mean?
I've read in other forums that E1 means the thermistor has failed. As far as I understand, it monitors the temperature of the air that is leaving the dryer and entering the dryer vent. If you're not handy, a service call is in order.
Mar 24, 2008 | Kenmore Elite HE4 Electric Dryer
Xerox Phaser  8500/DN Printer Logo
111 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
