Question about Dell Precision 380 P4 Dual Core 3 GHz (99382) PC Desktop
My pc do not work power
When i press the power button it not work.Please help me.Its a p4 dell machine. Thanks
  • 43 Answers
Open the CPU and check with the cord whethr it is loosened or not, please take care of electric shock, do not touch the circuit.
Posted on Jul 02, 2009
I HAVE DELL PRECSION WORKSTATION 380 PC. THE PROBLEM IS THAT WHEN I PRESS ITS ON BUTTON IT MAKES SOME BEEP SOUND FOR SOME TIME AND DONOT SHOW ANY DISPLAY ON THE MONITOR AT ALL. WHAT IS THE REASON OF IT ?...
Might be your Ram not inserted properly ,uplug your power cord and open your case cover, remove each ram and put it back one at a time and power on and see.Thank you.
Sep 03, 2011 | Dell Precision 380 P4 Dual Core 3 GHz...
Hi Everybody, My server Power Edge 650 asking to press F1 during every startup. How to get rid of this. Thanks Ezhilmani
Hi There.
Symptoms
* cmos checksum error messages
* error with date time error
Solution
* Replace CMOS battery.
Procedure
1. Locate your CMOS battery.
2. Turn of your Desktop.
3. Remove the power cable from your Desktop.
4. Press power button to discharge your Desktop from electricity.
5. Desktop should be laid down horizontally.
6. Remove the battery and avoid forcing.
7. Replace the battery with same model or equivalent.
8. Put the new battery firmly in the allocated slot. (Positive side should be visible).
9. Plug the power cabe and start up your PC.
10.Enter Bios by pressing DELETE or F2 and load defaults save and quit, it will reboot automatically.
11.Enter Bios modify settings save and quit.
12.The End
Hopefully this information helps.
Thank you for using FixYa.
Jul 19, 2011 | Dell Poweredge 650 - P4 3.0GHZ, 1GB/40GB...
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
I want upgrade my CPU from p4 520 to p4 660(2M L2 cache) on dimension 4700. I want to know if that will work on my pc. Right now i am operating on bios A05,and i want to know if i have to upgrade to bios...
For best results, you should run the Dell System Analyzer on your computer:
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&cs=19&s=dhs&~ck=anavml&dgc=SM&cid=54281&lid=1472034
Updating the BIOS, while not difficult, is not usually recommended unless it will solve a problem. The reason for that is you must follow the instructions provided by the manufacturer exactly or you could render your computer useless.
If the Dell System Analyzer determines that you can upgrade to a P4 660, then go ahead and replace the P4 520. If the P4 660 doesn't work, then the best approach would be to re-install the P4 520, make sure the computer works, then update the BIOS after carefully reading and understanding all the instructions provided by Dell.
Sep 13, 2010 | Dell Dimension 4700 PC Desktop
Dell insperion-power button only turns on green lock symbol with
If there is a small crack in the motherboard did you inspect it closely under magnification to ensure no tracings were broken? (These can be very difficult to detect even by tech's with years of experience) My money is on a bad trace on the mb.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 13, 2010 | Dell Inspiron 9300 Notebook
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
Power button flashes yellow and will not power up.
Try a different know good working power supply and only hook up the main power connector to the motherboard as well as the p4 connector. If you get power then you know that the original power supply is bad.
If you try another known good working power supply and you get the same yellow light then the motherboard is bad and would need to be replaced.
Jun 27, 2009 | Dell Dimension 3000 PC Desktop
Won't turn on when I press the front button
This sounds like your power supply; it's the part that the power cord plugs into that converts the power to dc and powers your motherboard, drives, and everything else inside your computer. You can pick one up for around $30 online or $80 at a retail store.
Thanks and please take a moment to rate as fixya.
Sep 08, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
140 people viewed this question
Alun Cox
