Question about Dometic RM2652 Refrigerator
Not working on ac on propane freezer gets down to
Not working on ac on propane freezer gets down to 17 degrees but lower unit stas mid fourty
There was ohm resistance there, but not a lot. After removing the heating element it only gets hot in about a 3" area of the tube/element. Transfer of heat was present but not a lot, you could touch it anywhere on the tube but in the 3" area. A typical hot water heater element either works or it doesn't meaning it it "open" but his has me baffled as I can't find any specs as to how many ohms it should read.
Posted on Jul 12, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Possible bad thermistor in the unit. Open the front fridge door and view the cooling fins across the back. On the right hand side is a clip with a wire going to it. Slide that up the cooling fins towards the top and see if that fixes the problem. If it does not, then access the rear panel and check the ohm resistance in the thermistor. Remove the cover of control board and unplug the two wire plug (white). Ohm resistance should be present on the thermistor.
Posted on Jul 11, 2009
I have a question how normal for the temperature for the freezer and referigator
Typical for a freezer is zero degrees farenheit and for the fridge is at between thirtee three and fourty, thirty eight would be great
Sep 06, 2015 | Refrigerators
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
RM 2611
the relay for the ac powered heater is stuck closed. it should cycle on and off , and not be on at all with the unit off.
Apr 17, 2014 | Dometic Refrigerators
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Fridge does not get cold during propane gas function only. Upper Freezer section does. Whole unit does perform and freeze and cold function fine with electric and generator function. Why only during...
According to the manual the following is the most likely items to cause that failure. But since it is only in the frigerator section and not the freezer section it could be the lower circuit board.
LP Gas
Orifice
Flue Baffle
Flue Tube
Burner
Lower Circuit Board
Sep 10, 2011 | Dometic RM2652 Refrigerator
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Fridge will not cool, freezer works fine
I have a similar problem on one of two NDR 1062's in my houseboat at Lake Shasta. We just had the recalls done on the electrical problem under the unit (whatever it was ours was on the list but OK). Now at #5 setting I am getting 27 degrees in the freezer box, but only 50-55 degrees in the bottom refrigerator. I had a temperature sensor cord going inside under the door gasket. The marina mechanic said to get rid of that, and we got down to 46 degrees. I checked the gasket and since the units are 9+ years old, I replaced the suspect part. Now at #3 setting we are still mid-20's in the freezer and at 39 degrees in the bottom box. Although the gasket seemed in good shape and pliable, a real close examination found several spots where contact was not good and I could feel cold air escaping. Hope that helps.
Jun 06, 2009 | Dometic NDR 1062 Refrigerator
Fridgadaire beverage center too warm
It should get cooler than that at least down to 33-34 degrees. Be sure you have air flow behind the unit, not pushed against wall. Feel for cold air coming from freezer to lower part just behind light bulb. If it is not turning off and defrosting they will do this as ice builds up and results in no air movement. you may want to remove the cover in the back of freezer and see if it is froze up. Or just turn it off and defrost and start back over the next day. The defroster timer may also be bad and it is under cover beside the light bulb.
Dec 26, 2008 | Frigidaire FRTB7B4EMB Top Freezer Beverage...
Refrigerator won't get colder than 45 degrees/ Freezer side is working fine
the fridge thermostat is not a true thermostat it controls a damper door the freezer thermostat runs the compressor in order for your refrigerators to reach the proper temp the freezer should be about -8 to-10 set your freezer thermostat lower and see if it gets lower .at the mid point setting it should be about -8 not 6 you may have a problem with its thermostat or a leak in your system reply to me tomorrow and tell me if lowering the freezer thermostat help we want it about -8or-10 and the best way to check your refrigerator temp is put a glass of water in it and stick your thermometer in it and if need be you can e mail me at b4829@yahoo.com just referance your promblem
Jun 03, 2008 | Refrigerators
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Dometic RM2652 Refrigerator Logo
425 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
