The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
SOURCE: ace r5315 No bootable device insert disk and press any key
Open the hard drive bay and ensure it is plugged in correctly. If that isn't the problem, try testing the hard drive. If it's ok, then the motherboard is gone.
SOURCE: Can't boot,showing "no bootable device,hit any key
Take it to an IT specialist as I suspect the hard drive may be dead.
SOURCE: Can't boot,showing No bootable device,hit any key.
First - re-seat the hard
disk and reboot the computer. If the computer does not boot up then reboot and
go into the BIOS configuration to see if the BIOS detects the hard drive. If it
doesn't detect the hard drive then it could be faulty.
Then the hard drive needs
to be replaced in the computer/laptop, Windows installed and the computer or
laptop's device drivers plus your programs etc. to get a functioning
computer/laptop again.
