Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I am getting a error 49 i can not fax or recieve faxes
  • anascentro May 11, 2010
    The 49 error is usually a memory error. Go through your menu to clear the stored memory & see if it prints out anything. If it doesn't, is it on a network?
    Problem Solver:
  • 19 Answers
In alot of cases it is because of a bad PDF file that someone is trying to print. turn the machine off and then on, but clear the print cue first.
If this is not the case than a memory SIMM may be the problem or main board.
Posted on Jul 07, 2009
4 Suggested Answers
  • 133 Answers
SOURCE: Brother mfc-7420n fax not recieving faxes, disconnecting
Please double check all cords and besure you are in the right plug.
Posted on May 22, 2009
SOURCE: We don't seem to be able to recieve faxes
Phone Co ran a check and it was due to bad fax line so they fixed it.
Posted on Jun 17, 2009
  • 1684 Answers
SOURCE: can not fax or recieve
The Error 49 message you are getting is caused by a board called a formatter, basically the brain of the unit. You can try to reset the board, this may work. If the error comes back then the board will need to be replaced before the error will go away. You can reset the formatter by going into the setup menu.
Setup then go to "Services", press "go" go to "Restore Defaults", press "go"
Beware, this will restore factory settings and clear all settings on the board such as your fax number, memory dial numbers, date and time.
Resetup your machine and you should be faxing again in no time at all..
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Aug 09, 2011
Sf5100 says recieve error
take the power out and hold the red button in. put the power back
Jul 21, 2011 | Samsung SF-5100 Plain Paper Laser Fax
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Jun 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Looking at fax earlier I notice a recieve error -
If you have a receive error then they will have a transmit error on their end. so they wiuld already know.
Hope this is of some help.
Ed
Apr 30, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
903 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
