I installed a generic black toner and started getting a black ghosting on all my printouts and also thin streaks of missing toner. I removed the generic after 10 or so pages but I am still getting the ghosting and streaking. Help
  • 43 Answers
Change the tonner and also clean the printer where the tonne ris fixed.
Posted on Jul 02, 2009
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
Tip
Why i get black streaks on paper in laser printer prints?
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks .
on Mar 18, 2010 | Office Equipment & Supplies
How do i remove a white streak that runs down the
there should be a black thin wire with a button to move over that wire that cleans it. I would also take out the toner and make sure there is no stains there
May 04, 2010 | OKI C5200n Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon 3220 toner streaking/ghost image
It might be afixing problem, but did you try to replace ITB cleaning blade?Its hard to say without seeing a copy/ test sheet
Jan 13, 2010 | Canon Office Equipment & Supplies
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
351 people viewed this question
jasbo
jasbo
