Question about Belkin (F5D7231-4) Wireless Router
Hi im having bit trouble with my router it is a (f5d7231-4 the wireless connection works fine even though signal low,yet when i try connect another comp from it i keep gettin an ip conflictkeeps telling me need re do ip pls help
  • rickster28 Jul 02, 2009
    hi ty for replying i have done that an still nothin,im trying to connect my xbox from router by cable the port its plugged in just blinks orange, also says i have local an internet access,i dont have the disc for router as was my mother inlaws, i checked ip adress according to my comp its 86.20.172.1 yet when i try put that in browser to connect to the router i get not found
  • 477 Answers
Hello
do you have dhcp on your router or do you have static ip:n on your computers? sounds like you have same ipn on both computers. you should change it to DHCP. go control panel networks settings then rightclick on your connection and properties click tcp/ipv4 settings and properties, mark optain an ip address automatically, also set dns automatically.
Posted on Jul 02, 2009
  • Filip Eastman Jul 03, 2009
    Hello, it seems like you dont have any dhcp ON. seems like you getting your IP address from your IP provider.
    1. start->run-> write "cmd" enter
    and in the black window type ipconfig. what is your ip address?
    also surf to www.whatismyip.com and look for your IP address is it the same ip on both places?
    get back to me when you tested this things I gonna search some info about your router.
    Seems like you have an other router than on the picture. the wireless router should be connteced to your Internet adsl/router modem. you cant connect any computers to your wireless router. can you explain more detail how your network are and what you want to establish.
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
My Belkin Wireless Adapter connects to the router but says there is no internet connection on my laptop even though there is when I connect to a hard line. All wires have been checked and other items are...
check what encryption your laptop will work with, if its an older laptop then its probably only 64 bit and your router is running on 128 bit encryption, and this will give what you have connected to router but no internet connection
Jan 04, 2011 | Belkin F5D7050TT Wireless Adapter
I have a hp officejet 6500 e709 all in one printer, i have been able to communicate without any problems wirelessly until recently. i had an error saying ink was low and had trouble printing, i assumed it...
This is one of the common connectivity issues marring the benefits of having a wireless printer. In this situation your printer will not print when connected wirelessly but would need you to set it up with your system using a USB cable. Try resetting the IP of your system to what is mentioned in the printer and in case there is a router connecting your printer and system then use the IP address of router and put it in your system. This should help you fix this printer issue.
Dec 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
I have a d link 615 and im trying to connect my dell precision M190 to it, but having problems even though it will connect to the network but Im unable to secure any internet
1. make sure your router is not near any cell phones, microwaves or TV's
2. Check your firewall settings
3. Make sure you have your router firmware updated.
4. connect your pc to the router physically this will let you know if your Ethernet card is working properly and you are getting signal from the ISP.
5. If you are connecting wirelessly then you have to make sure your router recognizes the PC's MAC (Media Access Control)
address.
To check to see if you have access and that the network see your PC
go to the command line and type ipconfig /all this will list all open network connection shown on the router.
this also can be done in the router.
6. Go into the router and check the status.
7. check the signal strength of the wireless it may not be connected.
8. Make sure your wireless adapter is active that is "enabled".
Apr 22, 2010 | Computers & Internet
Router stopped braodcasting the wireless signal WRT160N
maybe your router got fried somehow. it's a pretty common thing if you didn't disconnect the power scorce first.
Aug 12, 2009 | Linksys WRT160N Wireless Router
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
No wireless signal
Most home router has an IP address of 192.168.1.1 or 192.168.2.1. If you dad's laptop can connect to the router just fine, then it's a problem with your linux laptop. Can you see other wireless networks on your laptop?
Jul 23, 2008 | Belkin (F5D7231-4) Wireless Router
Keep loosing my wirless connection
Router setup page for a DLINK should be 192.168.0.1 Right click on the D and click on show available wireless networks. There maybe more than showing. If a neighbor has one or if you have another pc it might be trying to use rhe network card from that oc. Make sure that you click on DLINK for wireless connection. You just may see some other connections and find out that it's trying to use another connection.
Mar 18, 2008 | D-Link DSL-G604T Wireless Router
Wired works fine wireless does not
what is your ip and subnet addresses? are they complete? sometimes I enter my own in the alternate tab. eg.
ip; 192.168.1.105
sub; 255.255.255.0
gate; 192.168.1.1
dns; 192.168.1.1
alt dns; 192.168.0.1
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 31, 2007 | NetGear DG834G Router
Cannot connect a second pc
Are you connecting the machine that doesnt work wired or wireless??
Do you know what wireless card you have if it is wireless?
Dec 26, 2007 | Linksys Wireless-G WRT54GS Router...
Belkin (F5D7231-4) Wireless Router Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
