Question about Casio ClassPad 300 Calculator
Why my Casio classpad 330 can't turn on?
I change new battery still can't turn on
SOURCE:
SOURCE: casio classpad 300 plus
install FA-CP1 from disk
COnnect the calc
go to handheld assitant
click install add-ins
choose the game
*games an be found at planet casio, always end in .cpa*
Posted on Feb 08, 2009
  • 8081 Answers
SOURCE: how to use NumSolve on the Casio Classpad 330
Sorry the solution was posted as a clarification request. Here it is at the right place.
  1. Turn calculator ON.
  2. Look for the NumSolve icon.
  3. Tap the icon.
  4. The equation editor screen opens with the word Equation: on one line and a small rectangle on the next one.
  5. At the position of the rectangle, type in the equation.
  6. Do not forget the right hand side.
  7. Press [EXE].
All the non-numerical variables, parameters are then listed with a radio button next to each one of them.
  • Tap the radio button next to a variable and enter a value for a parameter.
  • Repeat for all known values.
  • Last, enter a guess for the unknown you are solving for and
  • set the bounds between which you suspect the solution to be.
  • While the radio button for the unknown is still checked, tap the Solve Menu at the top of the screen,
  • select Execute submenu and
  • press [EXE].
  • Alternatively you can tap the Solve at the left of the toolbar.(see picture).
If all goes well and the solution is found (this dependent of how good your guess is), the calculator returns with the value of the unknown and displays the difference
Left side-Right side = 0 or a very small number.
If the solution cannot be found you will be prompted to change the initial value (your guess) and/or the bounds. Hope it helps.
Posted on Dec 08, 2009
  • 47 Answers
SOURCE: how to do binary,hex BCD and decimal on casio
to convert between bases, go to keyboard, then cat(alog) and press B to scroll down to baseConvert(
syntax: baseConvert(value to change, original base, new base)
e.g. to convert 1100 from binary to decimal
baseConvert(1100,2,10)
Posted on Feb 18, 2010
  • 8081 Answers
SOURCE: how do i enter degrees minutes seconds on classpad
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
Posted on Sep 06, 2010
vetteman3002
  • 2299 Answers
SOURCE: Hi, I have a Casio
Yes, the touch screen is bad and will have to be replaced. This is a very common problem on these new touch screen devices. You should be able to take the unit to a local cell phone repair shop and have the screen replaces for around $80-$100.
Posted on Nov 01, 2010
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Casio Classpad 330 batteries run out very easily.
This may or may not solve your problem but it might alleviate it. The calculator has a power saving mode which you can configure as follows.
Turn ClassPad ON
Tap the Menu icon at the bottom of the screen.
Scroll down until you see the System Icon
Tap the system icon. After a few moments the calculator comes back and displays the system configuration screen.
At the top of the system configuration screen tap the battery icon (look for a + - sign).
This opens the power saving properties.
The power Save Mode will turn power saving mode automatically, after a day, one week or one month. It can also turn the power Save Mode OFF.
The other configurable setting is the auto Power OFF. It turns the calculator OFF after 1 min, 3 min, 6 min or 60 minutes.
Note: another possibility is the use of rechargeable NiMH batteries. Be aware that some manufacturers discourage strongly the use of rechargeable batteries.
Hope it helps
Apr 25, 2012 | Casio ClassPad 300 Calculator
How do I enter degrees minutes seconds on casio classpad 330
May 12, 2011 | Casio ClassPad 300 Calculator
Can you update a classpad 300 to a 330 operating system
It depends. If the ClassPad has OS 1.x you can upgrade it to 2.x freely. However you need to buy (separately) the ClassPad manager 3.x to be able to upgrade the OS to version 3.x. After that further upgrades appear to be free.
Feb 05, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
How do i enter degrees minutes seconds on classpad 330?
Sep 06, 2010 | Casio ClassPad 300 Calculator
How to do binary,hex BCD and decimal on casio classpad 330
Sep 14, 2009 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
44 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
