I got a 96 intruder just put a new battery in it yesterday rode it about a mile down the road game back left it running an wasn't long the lights went dim an it died what could it be anybody now help
SOURCE: Suzuki vs800 intruder dies after about a mile!
Sounds like water in the gas.
ALWAYS have a fire extinguisher on hand when working on carburetors.
For each carb > Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
SOURCE: 1995 suzuki 800 intruder looses amps back fires and dies
i would be looking at the voltage regulator,if the regulator is faulty the alternator will not be replacing the voltage that the bike needs to keep running
SOURCE: harley davidson battery went dead after riding
1.What?
2.What?
You charged the battery off of the battery charger with a trickle charge. The battery wouldn't charge while you're riding, because your alternator took a cr@p.
(Sorry if I seem gruff, but I'm an old biker, and Harleys are all I ride. I'm also a Harley mechanic.
Shhhh! I don't want that to get around! lol!)
3.Battery is at 13.4 volts now? What is the specific gravity of the acid in each cell? Don't have a hydrometer? Do you have a load tester? No? Since you measured the voltage, do you have a multimeter?
Test the voltage with the bike running. It should be around 14.6 volts when charging, less with the battery fully charged.
Don't get the correct reading, then you better look at alternator replacement. (Regulator is built in)
SOURCE: I have a 2007 VN 900 bike has approx 11500 miles
then your stator or regulator is bad on your bike.
SOURCE: charging system problem
start up the bike,put volt meter on battery terminals,if voltage rises with revs ,the anternator is okay,but if no volts then the alternator or the wiring to the battery is suspect
when i shut off my 2002 suzuki motorcyle it run perfect then went to start i and have no power battery good have no light on dash no head light brrake light everything is dead what could be wrong can you help with a idea thank you dave
