Question about Hitachi Televison & Video
Hitachi 50VS69A tv won't turn on anymore. Light engine replaced, worked for 3 months, then tv would turn off for a few seconds, red light wuold blink and then turn on again. Now it wont turn on at all. unplugged for 1 hour, still no reponse. Any ideas?
2 Suggested Answers
johnnydiode
  • 647 Answers
SOURCE: my hitachi 50vs69a tv wont turn on and after afew blinking red li
Have you replaced the lamp? Unplug the set remove the lamp and see if it's blown
Posted on Sep 20, 2009
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
My hitachi 50vs69a tv wont turn on and after afew blinking red li
Sep 20, 2009 | Hitachi 50VS69 50" Projection HDTV
My hitachi 50VS69A tv shows the picture green.
A green image is usually due to a lack of red or especially blue. the problem is becoming all too common with hitachi lcd projection sets. what happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far gone except to replace the light engine-at acost that makes it not worth repair. if the damage is minimal than to reduce further damage the air filter should be replaced. Light engine needsto be removed in order to replace the air filter.
Sep 04, 2009 | Hitachi 50VS69 50" Projection HDTV
50VS69A will not trun on, Lights just flash
its really hard to tell without being there to see what its actrually doing, Im asumed is out of warranty and few things you can do yourself. go ahead since its projection tv is to open the back up and check the fuses and the lamp, make sure is unplug and use a good lighting so you can truly see clear of the circuits board. some boad will have its own fuses and check them all make sure they are good. pull the lamp out and check it. projector tv are not hard to work on since is big and easy access behind the TV. to test the lamp you can take it to the local tv shop and have it tested for nothing. If all the lamp and fuses check out fine to fix your problems I would not think it will cost more than 150-200 to fix it. hope that help some ..Good luck
Jul 16, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
