Question about Sunfire True Sub MK II Subwoofer
Blown Driver Sunfire MKII True Sub, looking for replacement woofer.
Http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=297-460&ctab=2#Tabs
Posted on Oct 04, 2009
  • under2x Oct 12, 2010
    Worked for me, just took the old speaker out and dropped this one in no problem.
Own a Sunfire True Sub MKII, light on but no bass, when volume on all the way it barely hits. Fuses appear to be ok.Circuit board looked ok I dint notice any blown caps or miscolored resistors. Help?
Start with the volume way down on the sub.
Connect the line out of a source you know is working with cables you know work to the inputs of the sub. Try left and right.
This will let you know if the problem is in the sub or the output you're trying to use.
Oct 05, 2015 | Sunfire True Sub MK II Subwoofer
Sunfire true subwoofer signature one 7.5A internal fuse keeps burning out. what are possible causes and how to repair?
If you have an ohm meter (resistance) test for 7-8 ohms across each set of speaker leads to your sub woofer. Its likely you have blown speaker (load is causing amplifier to draw to much current) or just a bad amplifier in the sub (likely not worth $ repairing vs new). To test the sub woofer speaker itself you may have to take it apart to test its resistance.
May 26, 2014 | Durabrand STS98RW Theater System
How to determine if subwoofer is blown
check the box for air leaks, or rubber surround deterioraton.
Apr 03, 2013 | Sunfire True Sub MK II Subwoofer
My Sunfire MKll is making a popping/rattling sound during some low frequency notes, the sound is coming from the left woofer when facing the amplifier board ( its the softer woofer of the two, but...
The passive radiators on those are notorious for coming apart inside and making a knocking noise. You can sometimes glue it back together but youll have to remove the driver from the cabinet.
Jul 30, 2012 | Sunfire True Sub MK II Subwoofer
I am the proud owner of a SUNFIRE TRUE SUB SIGNITURE SUBWOOFER. THE ACTIVE 12" DRIVER. Has a torn rubber surround. I was surprised that sunfire neither services or provides parts for this $2500...
you can go to a hardware store and silicone caulk that is black, make sure it is flexible type. clean surface with rubbing alcohol and a cue tip to prep surface area well, allow alcohol to dry,apply silicone front and back of cone evenly bout 16th inch thick and let dry for full cure time on directions of silicone caulk tube. sub will work awesome. ive done this on many car subs of high amps and never had it fail. hope this helps you alot, i understand how it feels
Dec 30, 2010 | Sunfire True Sub Signature Subwoofer
Low volume on one of my sunfire true sub mkII. It works, but not nearly as loud as my other one?
Before we get too committed to a direction to go, or embark on unnecessary surgery, can we establish that we KNOW it's the speaker and not the amp or source? Perhaps you could swap it with the other one.
Back to basics: is this a sudden-onset problem or did it always behave like this? Try swapping locations with the other one. Bass response is a lot about location, location, location. Standing waves, self-cancellation, phasing. All players in this game.
Feb 14, 2010 | Sunfire True Sub Signature Subwoofer
Driver side speaker and sub woofer make an popping
they could be blown try replaceing them and see if it helps
Jul 27, 2009 | Car Audio & Video
Sunfire True Sub Constant Hum & Thump on Initial Signal
IF THE SUB HAS AUTO SIGNAL SWITCH THIS OFF BUT TO BE HONEST IT SOUNDS LIKE YOU HAVE A SPLIT VOICE COIL.
Jun 20, 2008 | Sunfire True Sub Signature Subwoofer
Sunfire True Sub MK II Subwoofer Logo
616 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
