When I turn on the TV a splash screen comes up reading HDMI then under it comes up DVI suppose to be 1080i. Then I get a no signal message.
The question really doesn't make sense. That's because 1080i is a signal resolution, and DVI is the connection cable that carries the signal. The two things are connected, but different.
It sounds as if your TV is searching for a signal; looking first at the HDMI input, and then the DVI input, before giving up because it found no signal.
Your next question should add some detail about the makes and models of the equipment involved and how you have them connected.
SOURCE: cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
SOURCE: DVI warnings when you connect HDMI cables
TV IS IN DEMO MODE GO IN OPTIONS MENU OF VIDEO AND TURN OFF. READ OWNERS MANUAL PAGE 80,81,82
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
SOURCE: HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
