Question about KitchenAid 24 in. KUDP02CR Built-in Dishwasher
I have a KitchenAide model KUDPO1FLBT2 dishwasher. When you open it, the door drops all the way down. What's wrong?
    Scholar:
  • 86 Answers
Most likely the Link - Door balance - brocken and need replacement. Remember the replacement parts come in 2 of everything that is for both sides on the door, even the other side is working but change it anyway , that is to get a even balance on both side, if you only change one side, the other side will go sooner or later and remember change everythings come in the package. Don't use the old one like the spring seen to be in good working order.God Bless.
Posted on Jul 11, 2009
  • Dickson LAU Jul 11, 2009
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
Kitchenaide Dishwasher Model # KUDS301XBL
Without having anything written down I can only imagine what the problem may be but I will give it a shot. The most common problem with dishwashers other than being too dirty it the timer inside the door. If the timer fails or there are contacts missing on the relays then the dishwasher may only do parts of the cycle or stop half way through. That is what I would check first, other than cleaning it of corse.
Sep 06, 2012 | KitchenAid Dishwashers
Kitchenaide dishwasher inner rubber seal nsticks to door when opening
clean seal and mating surface on door. then put a little cooking oil on seal. this may help.
Aug 07, 2012 | KitchenAid Dishwashers
KITCHENAIDE DISHWASHER KUDR25SH DOOR DROPS TO FLOOR
go to the next web:
www.repairclinic.com
God bless you
May 08, 2012 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaide KGST307 cracked inner oven window.
Open your oven door and look at the hinges. You should see a drop down thumb lock on each hinge that you pull down and after you do so, lift up on the door as to close. The door will catch on these thumb locks and then at this point continue to lift up on the door as you pull the door out at the bottom. Reverse directions to reinstall.
Apr 05, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaide builtin - take 20-30 pushes on start button
change the controls you can get at loocal appliance shop take model number when you go
Feb 17, 2009 | KitchenAid 34 in. KUDP01FLSS Stainless...
Kitchenaide dishwasher latch will not stay closed. It pops open during washing cycle and the machine stops and does not complete the cycle
The dishwasher was not properly leveled on installation. I used a carpenter's level
and trued up the problem. The door now stays closed.
However, the latch design is faulty in that it does not ever feel securely latched and that is true of all the Kitchenaides that I tried in the showrooms.
Jul 19, 2008 | KitchenAid Dishwashers
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid 24 in. KUDP02CR Built-in Dishwasher Logo
211 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
