Question about Insignia IS-LCDTV32 32 in. Television
How do you get the insignia 26 to a full screen
There are no "display," "cinema," or "full screen" options anywhere in the menu, so I don't know where the previous solution came from... However, if you go to "TV Menu," "Channel," and then select "Auto Zoom" and switch it off, you will be able to watch it in full screen.
Posted on Sep 02, 2009
    New Friend:
On the remote press Aspect until desired screen :)
Posted on Oct 04, 2013
Go to the display option from the menu and switch it to cinema or full screen, its not complicated
Posted on Jul 05, 2009
  • Kimmy Oct 04, 2013
3 Suggested Answers
  • 814 Answers
SOURCE: 26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Posted on May 10, 2009
SOURCE: 26" Insignia TV, screen is
I think your problem is in the lamps or in the inverter
Posted on Aug 12, 2012
Go to your menu and choose picture. See if your settings are normal or if the brightness is turned down. If it isn't then it's a problem with the T.V.
May 04, 2011 | Insignia LCDTV26 26 in. Television
Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Jan 21, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Screen is gone really bright and turning down contrast or brightness doesn't fix problem. Insignia LCD 26 inch
try turning down the backlight option in your menu. You should be able to find that option under picture settings.
Aug 07, 2009 | Insignia LCDTV26 26 in. Television
On my Insignia LCDTV26 I have almost 3" of black screen on the right and left side of the picture.
This is normal if you're watching a 4:3 (full screen) broadcast or movie on your widescreen (16:9) TV. You can adjust the screen aspect by going into the Settings Main Menu and selecting System, then Aspect Ratio. I hope this helps!
Jul 22, 2009 | Insignia LCDTV26 26 in. Television
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
Insignia tv 26 LCD tv/dvd combo problem
I have an Insignia 26' LCD TV with a built in DVD player and all I get on the screen is a box that says No Database.
Jul 26, 2008 | Insignia LCDTV26 26 in. Television
Flet screen tv insignia
Check the caps. 2 big blue ones. They are prob bubbling on the top which indicates they are bad.
Jun 15, 2007 | Insignia LCDTV26 26 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
1,908 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
