Question about Compaq Presario V4000 Notebook
I have same problem, that even got worse than that.
I had a similar problem with a toshiba, one that I had messed around with a little too much. Back then I didn't know much about wireless networking. It all happened right after i started messing with the "ipconfig" on the "RUN" menu. First it was like your problem, then I went back to do the ipconfig again, the next time my computer restarted, All the device manager disappeared, and none of the internet connection is there anymore, even my dvd player has dissapeared from the computer menu.
Toshiba e-studio 3510c
Check that the cable that comes out of the back of the feeder is plugged in completely. If not, turn off the machine and unplug the copier before plugging the adf connector in, then turn machine back on.
If that is not the problem, the sensor flag or sensor may be out of place. Where the paper goes in, there should be a black plastic flag hanging down that the paper will move when you insert it, If you can see it and it seems to move properly, then the sensor may be out of place or the sensor/feed medchanism is out of place and it is a little tricky to explain here. The sensor is above the flag, but under a metal plate and you may mess it up worse by trying to take it apart.
Nov 19, 2011 | Toshiba E-STUDIO 211C Copier
I found what looks like a card reader and an headphone input on the back of my t.v. (Toshiba REGZA 26HL47)by the power-cord and it was covered up by the manufacture... i was wondering if i up-grade the...
Miner modification design adjustment for a mass products productions fixes.99% of the LCD or plasma tvs out in sale for the consumers in the markets are never have to be upgraded or reinstall main frame firmware software at all,if u don't mess around in the main tv Tuner signal bard all.The main frame firmware software are alway and never suppose to be mess around for the tv entire life time anyway.
May 14, 2011 | Toshiba REGZA 26HL47 TV
I just bought a brand new Toshiba laptop. It hasn't even been a week yet , and i keep getting warnings saying there is a problem with your cooling fan. please turn it off immediately and return for...
the best thing to do is to return it while it is under warranty, it will only get worse and eventually mess up the processor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Dec 15, 2010 | Computers & Internet
How do i clean my air filter wr 400
remove the side cover
undo the nut in the middle and remove filter
take the foam of the frame
clean with a solvent, kero or similar
clean again in detergent and water
continue until spotless
let dry
use a air cleaner oil from a bike shop
put some oil on the foam and squeeze until oil is completly over filter( will be all the same color)
can do this inside a plastic bag to save the mess
fit back on frame
place a smear of grease around the edge that has to seal.
refit in air box, with centre bolt
feel all the way around to make sure it is sealing.
refit side cover.
doesnt matter too much if it is still a little wet
do this after every dusty ride
even twice on very dusty rides
I keep about 3-4 spare filters, clean in plastic bags, and wash them all together.
dont forget oil changes as well, they hold a bit over 1 litre, so change it often
Jun 16, 2010 | 2000 Yamaha WR 400 F
Sony ericsson k800i Not turning on
I had a similar issue, whereby my phone would turn on for 30 secs then the screen would go white and the phone would switch it self off then on.
After a lot of messing around even throwing the phone around the place. I took out the memory card and the phone worked fine. When I put the card back in, the phone started misbehaving again, so I guess the card is knackered.
Dec 30, 2008 | Sony Ericsson K800i Cellular Phone
Toshiba Plasma Power Supply replacement
Its kind of hard to mess up replacing a board in a TV, only thing to watch out for is the board can hold a charge after its unplugged even if its not working. Here is the service manual for your set.
Toshiba 50HP16 Service Manual
Dec 05, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Display Issue
Toshiba makes a great laptop but the display video or lcd seem to go bad very quickly I have replaced the lcd in many to solve this problem but be aware a few also had bad video cards (unlikley in your case as the external video is fine) it would seem as the lcd panel has gone bad on yours. the average replacment is around $100.00 to $300.00 depending on where you purchase from.
Oct 24, 2008 | Toshiba Satellite M115-S1061 Notebook
ASUS laptop model A6000 Power supply
I have a similar problem. The laptop switches into battery mode irregularry, even if no battery is inside. It runs stable with power cord connected for some minutes or hours, but sometimes switches off with no warning.
I have taken a new power cable, but still the same problem. The battery is broken, it only lasts some minutes.
Aug 07, 2008 | ASUS A6U Notebook
Toshiba pda e310
you may proceed to http://pcrepair.toshiba.com
Locate the most convenient service center in your location. Call the service center to confirm the issue.
Good Luck
Feb 02, 2008 | Toshiba e310 Pocket PC
Compaq Presario V4000 Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
