How can I find a free wiring schematic for a 95 ford f superduty for the spark plug into the distribution rotor?
SOURCE: i installed spark plug wires wrong on a 4.3 gm
Standing at front of truck, looking under the hood.
The closest cylinder to you on your right is #1. #2 is close left. #3
is middle right, #4 middle left. #5 is back right and #6 is back left.
Firing order is 1-6-5-4-3-2. This is the sequence for placing the wires
on distributor cap in a clockwise direction. #1 spot on cap is the 3rd
post after the wiring harness (clockwise). This post should be closest
to cylinder #5.
SOURCE: Need free pdf of 1988 chevy caprice wiring schematics for engine
go to autozone.com this should help with the schematics if not then go to a auto part store and buy a book the book should cost around 11.00$ and should fix your problem :)
SOURCE: I need a repair manual, schematics,wiring diagram
autozone.com sign up its free then click on repair manuals you will find all of your info there....good luck
SOURCE: car wont start, not getting spark
crankshaft sensor, or computer on toyotas then it was usually the distributor or the computer, but the crankshaft sensor might be bad too thats what helps to get you spark.
Fig. 1: Vacuum distribution schematic-3.8L engine
Fig. 2: Vacuum distribution schematic-3.8L engine
Hope this helps (reember to rate this answer).
