Roper RAX7245KQ Washer agitator does not rotate
Roper Washer agitator does not rotate.
RAX7245KQ Model number
SM8280871serial number
  • 5,911 Answers
If you are talking about the upper portion of the agitator (called the "auger") not spinning, you probably need to replace the agitator dogs. The following link epxlains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very simple and inexpenisve repair. The part number is included in the information I provided.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this information is helpful to you.
Posted on Jul 02, 2009
Sm8280871 washer. How do you take agitator out?
Are you sure this is a model number? It looks more like a Serial number. Model should be on a tag with serial number. Usually starts with letters then about 4 numbers and more letters. Providing that would likely get you better assistance.
Feb 17, 2015 | Roper Washing Machines
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
The agitator is not turning but i can hear the mechanism turning inside the agitator. is there a sheer pin broken? this is a roper heavy duty / large cap.( model #ral5144awo) top load washer.
AGIT DOGS ,,, go get or order whirlpool part number 80040
replace those and you should be good to go.. they are under the cap and have lil grippers on them that wear down and help rotate the agaitator assy..
Jan 28, 2010 | Roper Washing Machines
The agitator does not completely rotate unless you press down on it.
If this is a Whirlpool manufactured top loader with a split agitator design, this is commonly caused by worn agitator dogs. The upper portion of the agitator (called the auger) has a cam assembly with small agitator dogs that act as a clutching mechanism to drive the auger during the wash cycle. They wear out over time and need to periodically be replaced. The following link explains what they are and how to replace them:
The part number is included in the link I provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit which includes the dogs, cam, seals and washers.
If you have any questions, please let me know. If this is not a Whirlpool manufactured washer (which includes Kenmore, Roper, Estate, Frigidaire, Kelvinator) please let me know. If you are in doubt, please provide a model number and I can confirm for you. I hope this helps you.
Oct 04, 2009 | Washing Machines
Basin fills, does not agitate or drain
Check the lid switch. If you strip thwe wires and put on a wire nutit will go for ever For a switch call 7048196557
Mar 14, 2009 | Roper RAS8244KQ Top Load Washer
Top Load Roper Washer does not agitate during wash/rinse cycle
You may need to replace agitator dogs located inside the agitator or the drive coupler located above the motor. It dependis on which model you have.
Jan 02, 2009 | Roper RAB2121KW Top Load Washer
Roper washer, agitater stripped?
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Aug 06, 2008 | Roper RAX7244KQ Top Load Washer
Roper model ras8445kq0
If the agitator does not spin at all, then it is your motor coupling. If the agitator tries to spin but cannot, then it is your dog agitators.
Mar 14, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
388 people viewed this question
Top Washing Machines Experts
