Fan not spinning
The air conditioning fan is not spinning?
  • 52 Answers
Either open motor or bad capacitor. if it is a bad capacitor you should be able to start fan by spinning it with a call for cooling. it it has tight resistance it is bad start windings if its free spinning it is open windings
Posted on Aug 29, 2009
Air condition problems
No it shouldn't unless activated by the fan switch. If the fan switch is activated, then probably not enough freon in the system.
May 17, 2013 | 1994 Mercury Grand Marquis
Air condition motor not going on
check to see if the fan is running if not it has frozen up over the winter. turn off fuses to a/c unit then try to turn fan by hand,if not soak down fan bearings with penetrating oil like PB Blaster keepmoving fan blade back and forth until it spins freely. Then try turning on the power to a/c unit if motor then turns fan freely , shut it down again and use a good coat of a-1 motor oil (ELECTRICAL) on the fan brgs. This should get you through for another year or so. On the other hand if fan will not spin by the motor now but spins by hand then the fan motor is bad.
Apr 14, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Air conditioning fan wont work
Test the fan with a wire hooked direct to the fan motor then touch the other end to the battery positive terminal. If it hums or does not spin replace the fan. If working the relay is at fault
May 20, 2010 | 1999 Jeep Grand Cherokee
I have an old Tempstar air condition and when I turn it on the compressor runs and the fan looks like is is wanting to turn but it quits. HELP me
Check the voltage on the fan connections. Bad connections cause resistance to current. If connections & voltage are good than the problem is probably your fan motor if its clean from dirt/grease/dust etc. Plug off the unit and try to spin fan blades with a pencil and observe if rotor is turning freely. If its spin normal than again your fan motor is not good.
If its try to spin on its own when the units turned on and creates excessive heat, this indications generally pointed an abnormal resistance problem at the circuitry or on the power consumed points of the unit.
Jul 08, 2009 | Ruud Central System Air Conditioner
Fan won't spin due to bracket broken
I would try www.Repairclinic.com . You can usually find the bracket there. Or a universal retrofit. Good luck.
Apr 17, 2009 | Heating & Cooling
Cooling fan
Replace the cooling fan sending unit.
Sep 04, 2008 | 1998 Toyota Camry
Simplicity air conditioner
I had an e1 error, the fan was spinning but the compressor dosen't.  I don't know witch step i made fix the problem but try it.  I unplug the air conditioning for few minutes, unplug the control panel, get every things  back and it's work fine.I wish that can help youFrançois
Jul 10, 2008 | Kitchen Appliances - Others
Air conditioning
try un pluggin the fans and running 12 volts direct to fan motors if thet spin fans are good if not then u have another issue
Jun 19, 2008 | 1997 Lincoln Continental
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
