Apple iPad (16 GB) WiFi Tablet PC Logo
brian Woodhouse Posted on Sep 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipad settings I can not enter my ipad 1, lost passport how do I get in now
Thomas Beaver
Level 3:
  • Apple Master 2,119 Answers
  • Posted on Sep 04, 2014
Thomas Beaver
Apple Master
Level 3:
Answers
2119
Questions
0
Helped
751270
Points
6319
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
2answers
How to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
My mini ipad is disabled connect to iTune
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Connecting to iTunes, only works if you had it installed on your computer and made a backup on the PC. If you know the password belonging to the Apple ID o the screen, you could try entering that.
Or perhaps you try this site?
http://www.wikihow.com/Reset-a-Forgotten-Password-for-an-iOS-Device
I forgot my user name and password
I can unlock my iPad its disabled in it say to connect it to iTunes but I want to can I reset it without connect it to iTunes cause I don't have a computer to do it.... If I can reset it to unlock it is my...
Perhaps you even could try this? How to Reset Forgotten Password for an iOS Device
1helpful
2answers
How to unlock ipad2 puk code
Your iPad 2 must have 3G, with a sim card. For the sim you need the pin and after 3 misses you need the puk. The puk is on the letter or card that came with the original sim card. On that letter is the pin and puk. sometimes you have to scratch away the metal layer.
If you want to unlock an iPad, with the lock code on, and forgot your pass code you have to enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
How do i restore my password disabled ipad?
You can enter the recovery mode in iTunes and restore password on your disabled iPad. Just follow below steps to do that.
iPad Air
iPad mini/iPad pro
restoring-ipad-software-2ka233npl0212ndjbhnpio3z-3-0.png For more methods, check: How to Unlock iPad?
1helpful
I can't remember my login on my iPad when I try to back it up on my HP laptop am advised to go to iCloud and turn it off. Is there anyway I could retrieve my login or else just turn off
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
Be aware if Apple cols and want to reset your iPad, all data now on the iPad will be lost.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
