Question about Frigidaire Refrigerators
Condensor fan not working compressor not working
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Maytag Refigerator Condensor Fan not Running
yes it is your getting proper voltage, fan simply went bad, center mullkion was the unit trying to disperse the heat the fan was not able to!
Posted on Nov 17, 2008
  • 327 Answers
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Dec 19, 2008
  • 358 Answers
SOURCE: Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
Posted on Apr 21, 2009
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
My fridge is not colling and compressor geting heat.
If this is a SxS , the overload/relay which plugs onto the compressor is probably bad if the compressor clicks off or does not run at all ,OR , the fan which cools the compressor (condensor fan ) is not working (bad motor ) , also make sure the coils are clean at the bottom in the front (condensor coils ) .
Jul 25, 2009 | Whirlpool Refrigerators
The AC in my 2004 Honda Accord only blows cool air when I am driving at higher speeds. When I drive slow or am stopped, it's warm hair coming out. My mechanic said the compressor isn't working properly...
it is a premature failure, That does indicate a bad/failiing compressor, or low oil charge, to low freon. If you trust the mechanic then go witht he compressor replacement and condensor. Unfortunately most oarts stores/shops require the condesor to be replaced for warranty purposes on compressor replacements.
Jul 22, 2009 | 2004 Honda Accord
Freezer on bottom is working normally, but refrigerator on top is warm. The condensor fan is working, condensor is clean, compressor runs.
The condenser fan only circulates air around the condenser and compressor. There should be another fan that circulates the air around the refrigerator, it should be located inside of the freezer section at the rear. I would look for this fan and see if it is operating first.
Jul 19, 2009 | Refrigerators
Nov 01, 2008 | Maytag MZD2766GES Side by Side...
True TDD-1 beer kegerator condensor fan not running
cenck for volatge at wire harness and if you get the right volatge then repl condenser motor you can use a small portable fan just face it at compressor while you look for part and tha will kepp compressor from over heating and tripping the relay on it ok
Oct 15, 2008 | Refrigerators
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
