That's an error code.you can find out what number of beeps for your machine mean through google, usually three or four means ram memory chips are playing up.sometimes cured by reseating them.if there is more than one take them all out and the put them back one at a time .you may find the faulty one that way. cmos battery exhausted will give continous beeps.
SOURCE: 3 beeps and fan running at start up
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
SOURCE: Dell dimension 4600, won't boot,
hi...you can try to factory reset it if you have an authentic version of windows, by restarting your computer and pressing F8 as it starts, would advise backing up all your files however before doing this
