Question about Whirlpool Dryers
The heat sensor is not working on my Whirlpool Gold. The hot setting has left burn marks on my husband's shirt. Should I get dryer repaired, or replace it?
    Problem Solver:
  • 7 Answers
Repair. Have the venting system cleaned -to eliminate this out of the equation, After that, If your dryer is getting too hot after this, a sensor shuts off the circuit to light the gas (or heat the element-electric). It needs to be checked and may be bad.
Posted on Jul 02, 2009
What would cause my clothes dryer to burn a hole in a shirt
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 18, 2011 | Whirlpool Dryers
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
It still heats up and has not tripped the breaker,
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 12, 2010 | Whirlpool LER5636P Electric Dryer
Dryer tumbles, but does not blow hot air
perhaps the heating element has broken
is it electric or gas?
Jan 09, 2010 | Whirlpool LGR7646E Dryer
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
My dryer doesn't heat up
I had the same problem. I called the repair man and my heating elements were broken, I had them replaced and now my dryer works fine. For me getting it repaired was cheaper then buying a new one. Your repair man should give you a free estimate on the cost
Dec 15, 2008 | Roper REX4634KQ Electric Dryer
Oven too hot!!
sounds like a bad oven temp sensor, small 3-6 inch, metal probe in upper left corner of inner cavity, 2 screws and the sensor should pull right out, replace you should be fine
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
