Question about Dell 1815dn All-In-One Laser Printer
HOW RESET COUNTER FUSER DELL MFP1815
HI ,, I HAVE SERVICE TAG HWNPD91 MFP1815DN LASER PRINTER
I CHANGE THE FUSER BUT I CANT FIND HOW RESET THE COUNTER OF SERVICE
THANKS
jaylex
  • 417 Answers
SOURCE: dell laser printer m5200: 922 service fuser error
The fuser is not warming up replace fuser.
Thanks J
Posted on Jan 19, 2008
jtuminaro
  • 56 Answers
SOURCE: Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Posted on Jan 14, 2009
  • 5 Answers
SOURCE: RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
Posted on Aug 12, 2009
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
This drove me crazy recently...
The Reset Parts Life option is not available unless the "Drum End Soon" message is on the display. If you replace the drum before this message appears, you'll have to wait to reset the count.
Posted on Sep 21, 2009
brett207
  • 231 Answers
SOURCE: Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
Posted on Feb 02, 2010
Reset fuser message on dell 5130
Johnathan, Reset the life counter:
  1. Enter the printer's tech mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If tech mode does not appear, Re do key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select tech menu , data setup, Clear fuser count.
  3. Restart the printer.
  4. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Knowledge Base
Replacing the Fuser on Dell 5130cdn Laser Printer
https://www.sosnfl.com/wp-content/uploads/2014/12/Dell-5130cdn-Users-Guide.pdf
Apr 09, 2016 | Dell 5130cdn Color Laser Printer
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
How to replace dell 1250c fuser?
To reset the life counter:
  1. Enter the printer's Tech Mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If Tech Mode doesn't appear, press the key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select Tech Menu > Data Setup > Clear Fuser Count.
Read More... Replace the fuser and reset the life counter on Dell 5330dn laser...
And Dell Printer Support
Thanks,
Jul 30, 2014 | Dell Office Equipment & Supplies
Dell laser mfp1815 won't print after installation
hi, first make sure that the drive you installed is Compactivel with the operating system of your printer.
second if windows operating system make the numbers of bits (32 or 64).
third sure the paper setting this right.
Sep 16, 2013 | Dell 1815dn All-In-One Laser Printer
NEED PRICE ON FUSER FOR DELL LASERJET MFP1815DN
Iteminc.com has that fuser new in stock for $99. Part#UG297. Here is a video that shows you how to replace it.
Aug 15, 2011 | Dell 1815dn All-In-One Laser Printer
How do you reset the fuser counter, or page counter, on a dell 5330?
There is no mention of resetting the counters during the replacement process in the manual for the printer. (Link below) Try powering off the printer by using a switch or unplugging it.
Manual:
http://support.dell.com/support/edocs/systems/5330DN/en/index.htm
Mar 02, 2011 | Dell 5330dn Laser Printer
FUSER COUNT RESET
The above solution doesn't help, the poster requested how to reset the fuser count replacing the fuser doesn't automatically reset the counter.
Aug 12, 2010 | Brother HL 5250DN Laser Printer
I replaced the Imaging Durm,but the light is still flashing w/ the error light. It's a Dell 1720dn Service Tag 25MS7D1
Did you reset the counter?
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button cancel_button_0.jpg until all lights flash in sequence.
I hope this helps.
May 20, 2010 | Dell 1720dn Laser Printer
T8006
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
Jun 18, 2007 | Tally T8006 Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
836 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
