Question about Refrigerators
The frigerator and freezer are not getting cold enough.
I have a Frigidaire FRS26ZGGW4 side by side refrigerator. The frigerator and freezer are not getting cold enough. I have vacuumed the coils and let refrigerator run overnight, but still have not solved the problem. I also had no luck in locating a graphic diagram for locating parts to troubleshoot for my model
  • 158 Answers
It sounds as if your unit is low on freon.You will need to have a quailfied repair person to refill.
Posted on Jul 02, 2009
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
It freezes the frigerator side
check for ice build up on the damper door located between the freezer and refrigerator compartments and make sure it can open and close as you adjust the refrigerator cold control,if so defrost it with a hair dryer and then try it for operation
Feb 20, 2010 | Frigidaire PLHS267ZA Side by Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Jul 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Freezer not cold enough warm on the frigerator area
Replace the defrost heaters and or the bi-metal. Also make sure that all the ice is off the evap coil.
Jun 29, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
