Question about HP OfficeJet J4580 All-In-One Laser Printer
I can't manage to scan directly from the scanner
After I've installed HP Officejet J4580, everything worked properly except the scanner. I manage to scan only through my pc but directly from the printer I can't manage to scan from some reason. Every time that I try to scan an error appears with the following message :
NO SCAN OPTIONS. REFER TO DEVICE DOCUMENTATION TO TROUBLESHOOT.
I really appreciate if someone tells me if I can scan directly from the printer because I don't think so that in the printer there is an option and one can't use it.
Please help.
  • 477 Answers
Hello
Have you installed full software from the CD that came with the printer?
if not do that first, do you mean that you cant push printer button and automatic scan to computer?
Posted on Jul 02, 2009
4 Suggested Answers
  • 82 Answers
SOURCE: Comp freezes and "no scan options" message
try downloading the 2 firmware patches fro hp. go to www.hp.com select support, drivers and downloads, enter your printer model, and select your os. Halfway down the next page is the firmware section. Download and install.
Posted on Aug 08, 2009
  • 5 Answers
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
Posted on Feb 16, 2010
  • 53 Answers
SOURCE: J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
Posted on Jun 02, 2010
I keep trying to scan a document on my hp officejet j4580 all i n one that i just installed and itkeeps saying refer to device documents, no scan option.. what should i do i cant find ne thing about it in...
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
I just downloaded and installed a driver for HP Officejet J4580. When I try to scan it says there are not scan options. What do I need to do?
If you are not getting scan options, make sure you have installed the scanning software along with your drivers.
Check in Control Panel / Scanners and Cameras and try to scan from there.
Thanks,
Pat
May 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
I have an HP Officejet J4580 all in one, and I can't get it to scan to my laptop. There are no actual instructions to guide a scan. I tried to find a manual online and can't seem to find a site.I have a...
The manual for this printer is available here from HP, and it covers the scanning operations. You can also download the HP software here which will allow you to directly scan to your computer. If you don't use the HP software, you can use the Windows Scanner and Camera Wizard to scan.
Apr 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
It won't let me scan. it says "no scan option". my printer is hp officejet j4580 all-in-one-
Try reinstalling the software and make sure you follow the directions, because usually you have to install the software first before plugging the printer into the computer
Feb 19, 2010 | HP OfficeJet J4580 All-In-One Laser...
How to use scanner on HP officejet J4580 all in one?
Click here to visit the HP support page for this model. You will find an online manual with complete instructions for download free of charge.
Nov 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Aug 08, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Scanner not scanning
u will need to download the installation driver from the cd to make the scanner work properly. as the printer drivers r loaded but the scanner drivers did not got loaded. check out this and reinstall the drivers.
Jan 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
312 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
