Question about Pioneer Mag Card Reader (Tracks 1 and 2, External Y-Cable) (STLHD12Y)
Gemini card reader is not working - Pioneer Mag Card Reader (Tracks 1 and 2, External Y-Cable) (STLHD12Y)
  • 818 Answers
Start
* Contol Panel
* Performance and Maintenance
* Administrative Tools
* Services
* Smart Card( check if its active and started manually)
* If not click twice and start it ,then click ok.
* Reboot your computer (I shut it down holding the main button in for a few sec)
If thats ok, remove the cables from the motherboard. Boot the pc, shutdown, reconnect the cables & reboot.
Posted on Jul 02, 2009
How do i do a factory reset on my Gemini D7
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Apr 25, 2015 | Android Gemini Tab
Lower the fan speed on Gemini XGA-4000 Amp
Your card regulates the speed of your card?, then you can instal a same , only higer efficient fan or just lower the temp of the surrounding, lowering the fan speed ain't smart at the moment, since it propably needs the cooling. Can't you place a largercooling block?
Oct 22, 2014 | Gemini DJ Gemini XGA-4000 Power Amp
Gemini FIRSTMIX PRO can't volume on master output
Dear Joshua Chan, I suspect there is a problem with your sound card driver. Could you please try to use some free driver update software and see if this tackles the issue?
Jan 26, 2014 | Gemini DJ Gemini Firstmix Pro DJ Software...
My midi cable is not detecting my laptop again because i reload it
IS IT USB - MIDI? TURN THE MIDI BACK ON IN YOUR SOUND CARD SETTINGS,& ON YOUR DEVICE.
Oct 25, 2013 | Gemini DJ Gemini CDJ-700
How to connect the gemini to the computer
Easy.
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 12, 2011 | Philips Gemini CDM-500
Centros Secure Digital Card Reader Model No.4418951 will not read a SanDisk SDHC Card 4GB.
1. Safely remove the Card and Card Reader from your system.
2. Plug in the Card Reader to the system.
3. Now, insert the Card in the reader.
4. Let the system take some time to detect the devices.
* If the Card Reader donot read the card, try another card to check if there is problem with the reader or card!
* If the Card Reader still donot detect, check it with another system.
tell me if it works...tc! :)
Dec 31, 2009 | Computers & Internet
GEMINI PC TV TUNER W/O FM DRIVER
i want the driver for gemini tv tuner palbg
May 08, 2009 | ASUS TV/FM 7135 (TVFM7135WREMOTE) Video...
Appian Gemini - full screen within one monitor in dual screen
TRY CTRL + B KEY
OR CHECK OUT THIS WEB SITE:
www.marctalkstech.com/guides.html
Feb 01, 2009 | Appian Graphics Gemini (16 MB) PCI Graphic...
Televison & Video Logo
50 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
