Question about Portable Televisions
Supra str 2101
'I lost my tv remote for supra multi system , i have bought universal remote (visa electronics) and is not working what do you think i should buy now.
4 Suggested Answers
SOURCE: Remotes won't work with Sanyo Tv
12345gut 7twryt iouoiopu p0ouhjbhb vytv6frsawzs sxfhjkliyffvvvnjhukjkjhiuhj hggggggghjyut7u 67 y 69455230528455659+56525555555555555555555hju khk*********mjinjknkjnjk89wdeqqzaesfbh jj jtfvghtrrgh bhhjvugjhiuf yuh uh iu iiiih ui u u uyyyyyyyyyyyyyyyyuyuiy7htgg5555555bhh dhju yg ugsgxxh yusyyhyhzghgxtyc gfyt syu6780
Posted on May 18, 2008
  • 240 Answers
SOURCE: remote
yes i have provided you with the link
Posted on Jan 14, 2009
  • 136 Answers
SOURCE: I bought a used GE TV at a resale shop. It didn't
i would buy an GE Universal Remote. Any GE Universal Remote will work with any GE TV's. Just like a Magnavox Universal Remote will work with Magnavox without programming it.
Posted on Mar 14, 2010
  • 8457 Answers
Try website like to buy an original or very close to the original remote.
Posted on Jun 23, 2010
0 characters
1 Points
I'm trying to find a universal remote that will work my 13" naxa tv
Unfortunately, naxa tv's aren't compatible with universal remotes, as they use a proprietary coding system for their tv's.
Your only hope is to contact Naxa's support department at to ask about replacement remote.
This is directly from their website about the incompatibility with universal remotes.
I know you were hoping you could use a universal remote for your tv, but sadly that's not the case here.
I wish I could have given you better news, but it is the way they designed their sets, that's why universal's don't work.
I hope this helps you out in knowing what to do now, and have a good day.
May 25, 2011 | Naxa Electronics Nx-540 13 in. Portable TV
I bought a used GE TV at a resale shop. It didn't have a remote with it though. I bought a universal remote and it doesn't work for it either. The universal remote does work on another tv in the house...
Mar 05, 2010 | Portable Televisions
Toshiba television and universal remote problems
Hi, as the sets get older the codes for older models get deleted to make room in the remotes memory chip for the newer models, this is probably why none of the universals will work for you, post the model number found on the back cover of your tv & I`ll look it up to see if theres a sub or the original is still available, video-tek
Jun 05, 2009 | Portable Televisions
Set up for universal remote not working
I have a phillips remote tv controller universal. I lost my papers so I need to have the codes to use in my magnavox tv. Please send me the codes. Thank you.
Dec 10, 2008 | Portable Televisions
Tv front panel is locked
you must get a new remote not a universal this wont work as the tv is off hope this helps some one
Mar 29, 2008 | Portable Televisions
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Nov 04, 2007 | Portable Televisions
Universal remote
call for a factory remote at1-800-736-6837
Nov 01, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Portable Televisions Logo
59 people viewed this question
Top Portable Televisions Experts
Are you a Portable Television Expert? Answer questions, earn points and help others
