Question about Protron PLTV3250 32 in. LCD Television
The power supply doesnt work ,not able to turn on
Hp m7360n green light on in back but no power
check the power supply
after doing this if the power fan turns on means your power supply is working properly.
if it doesnt work there is problem with your motherboard
May 17, 2014 | HP Pavilion a1250n (EG194AA) PC Desktop
Hp pc m7360n no power
after doing this if the power supply fan turns on means your power supply if working fine and if it doesnt work there is problem with power supply.
if the fan turns on and still there is no power there is problem with mother board
May 16, 2014 | HP Pavilion Media Center TV m7360n...
My monitor hp w1858 wont turn on
Your monitor may have developed a power supply problem since being refurbished
Jul 04, 2013 | HP Refurbished 18.5" Widescreen Monitor...
My player doesnt work anymore display is not working and it doesnt turn on anymore? what do i do?
Hi, thats look like its the power supply,
a zener diode and some caoacitor or its could be the fuse
if the fuse is dark burn inside thats indicate a good short circuit
on the primary side off the power supply,
hope that will help
regards Alan
Oct 09, 2010 | Pioneer BDP-51FD Blu-Ray Player
My power brick light is yellow until i turn on the console then it turns red. whats wrong?
The power supply turns red when it detects a fault such as the power supply has to much current, the voltage is too high or the temperature of the unit is too high.
A few ways to trouble shoot this would be .
1. make sure the power supply is cool
2. try plugging the supply directly into the wall instead of a surge protector ,
3. if that doesnt work call 1800 4 MYXBOX and get a new power supply.
Dec 13, 2009 | Video Game Consoles & Games
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 08, 2008 | Akai LCT3201TD 32 in. LCD Television
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Power supply doesnt turn on
There are several solutions
1. Plugs should be placed correctly
2. The should be power comming into the sockets
3. The voltage switcher should be on the correct voltage... it may be on 220 V while your power in your country would be 110 V so check it
4. Fuse may be blown out
if the 3 dont work contact me again if the fuse may be blown out,, it may be a greater problem
Dec 10, 2007 | Computers & Internet
Protron PLTV3250 32 in. LCD Television Logo
141 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
