Question about Broan-NuTone MHS120L Combination Light Fan Exhaust Fan
My motion sensor ligth stays on all the time
I have problem with my motion sensor light, it never turns off. Please help me I appreciate.
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
I have a motion detection plug in security light, is it possibel to get it to stay on all the time?
if then light is on all the time what is the point of having a motion detector unit as it is designed to switch on a light when motion is detected
the light switch on when there is no motion but as soon as detected the light comes on primarily to light the way for you or to scare off intruders
having the light on all of the time is a waste of energy
Sep 04, 2017 | The Home Security
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
Light stays on all of the time will not turn off
Adjust the timer setting under the sensor it might be set to zero you shuld adnust to about 3 minutes or desidered time if set to minimum light will stay on if this does not help change unit its faulty
Sep 25, 2017 | Heath Zenith Secure Home Motion Activated...
Cannot get light to go on and then off at programmed time. Stays on. At cottage with no neighbours or ambient light. Installed professionally, not by myself. Frustrated many efforts before contacting...
Light stays on all the time: Turn power to light off. Wait 10 seconds. Turn power back on.
Typical option on motion lights: Quick power flick -- light stays on. Slow power flick -- light goes into motion sensing mode.
Hopefully the professional installer gave you a switch.
Jun 01, 2011 | Heath Zenith SL-5318-WH Dual Brite Motion...
My brother has changed a sensor because the check engene ligth was on after he replace it the ligth went off but my car do not stay on after he warm up i rrealy do not now what is the new problem he think...
ignition control moduel is bad .they work until they get hot ,then they will turn the motor off because this moduel controls your spark to your plugs..Check with Auto Parts store,they are easy to replace just make sure you use the right size tool to take the screws offf..
May 26, 2011 | Chevrolet Monte Carlo Cars & Trucks
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
I have motion lightts on my back porch. I would like to just plain turn them on when I have a back yard party, but I don't know how to over ride the motion sensor. Can you help? Thanks.
On most motion sensor lights if you turn the switch on, then off and on quickly, they will stay on till you turn them back off. Leave it off for at least 10 seconds and turn it back on to go back to the motion sensor.
Sep 06, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
Dual Brite sensor lighting. Lights will not stay on even after human motion is in place sight of sensor during evening hours. I have the switches on dusk to dawn and the on-time switch is set to 20...
I really don't understand why these lights are so failure prone and I usually return at least 8 out of 10 back to the store but I've installed a lot of them. If its Zenith brand the light may need to be reset by turning the power off at the switch or breaker for 1-2 min then back on. Then check the motion sensitivity dial if its maxed out turn it back and set it to 75% full also the photo eye may be getting light from the light making it think its daytime at night so try to reaim the photo eye if possible away from the light source that should fix most problems or 20% of them but if you still have problems return it to the store or ask for their advise. Hope this helps I've seen a lot of junk motion lights in my time they are troublesome at times.
Jul 12, 2009 | Electronics - Others
Motion sensor light stay on
Hi, You don't say what the make or model is, so I will give you the best advice I can. Most motion sensor lights today have a switch or two on them for "on", "test" and then some time like 3 minutes, or 5 minutes. The switch is tiny so it or they are easy to overlook. The "on" position will keep the light on all of the time. The test position does different things on different models but you will want one of the time settings. If this doesn't work for you get back to me with a little more info and we'll keep on it. Good Luck!
Feb 06, 2009 | APC Electrical Supplies
Broan-NuTone MHS120L Combination Light Fan Exhaust Fan Logo
148 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
