Question about Dell OptiPlex GX270 Small Mini-Tower Desktop (162823025)
Hard drive has been wiped trying to re boot from windows xp cd. changed battery on mother board. getting alert low battery voltage and pc will not re boot. asking re boot trying pressing F1
    President:
  • 1,179 Answers
It sounds like you either got a bad battery or one that is not compatible with your motherboard. Try replacing with a new battery that is compatible with your mb & see if this corrects the error. If you just bought the other battery you are using you should be able to get a refund or store credit towards the new one. Also make sure all the cables are properly seated as one may have come lose during original replacement. Hope this helps.
Posted on Jul 02, 2009
What is the password for Gateway Essential 566c Desktop PC
if you are able to open the pc open it. Remove the cmos battery and turn on the pc and again turn of the pc and install the battery again. if it doesnt work try to locate the cmos jumper on the mother board and clear the bios
May 26, 2014 | Gateway Essential 500 PC Desktop
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
I wiped my hard drive using kill disk. I have a Windows XP home disc to install the operating system, but when I boot the computer, I get the "Error loading operating system" message and it won't...
when you boot the laptop, if you don't see a message that says press any key to boot from CD, your boot order is wrong.
Check your boot order, when you see the splash screen (logo) look for a message that says press a F1-F12 key to change boot order or if that message is not displayed, press the key to enter setup.
Look for an option that list boot order and shows your hard drive, CD/DVD and USB options.
Move the CD/DVD item to the top of the list and try again.
Feb 11, 2011 | Gateway Computers & Internet
Error "Setup didn't find HDD"
Well, first of all XP is not the latest supported operating system from Microsoft.
That being said, I have not had a garbled screen followed by an error message 'setup didn't find any hard disk drive installed' on a laptop, in my limited experience with laptops (i.e. Acer One, Acer Aspire, Sony Vaio, etc.)
If you have an unexpected garbled screen it points to the pc board or mother board or the video card, but more likely the motherboard.
And, if you couple this with the hard disk drive not being detected, it reminds me of a situation where I had a no hard disk drive detected on a SCSI drive connected to my Windows 95 computer in the 1990s when I had heat related issues with the circuitry on the hard drive getting burnt out capacitors.
If the drive is not recognized, it might mean the boot sector is wiped, and essentially it needs to be reformatted and the operating system needs to be reinstalled (which you evidently tried to do).
To my memory, I never had this problem on Windows XP with a laptop, so I am thinking it's not Windows that is at fault, but the physical hardware is giving you problems.
If you boot from the CD for Windows XP and it doesn't find the drive, it's a big problem for this laptop.
I wish you luck in finding an answer to that one, seeing that it's out of warranty and XP is no longer supported by Microsoft.com.
Jul 19, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Can't instal xp
You can try and tap on the F8 key when the computer is booting up and see if an optional boot menu pops up and if it does then select the CD-Rom Drive to boot from the CD, and if not then you will have to go into your BIOS setup and change the boot sequence to boot from the CD-Rom Drive first. Also, if you already have windows on the hard drive and you are using a modified boot screen you might get an error when you try to install XP.
Jun 10, 2010 | IBM (25P3294) Motherboard
Want to wipe hard drive on dell dimension 8250
You don't need a recovery cd (or any other cd) to wipe the hard drive. Boot to a command prompt and type "format c:"
Reinstalling your operating system is the only time you need a recovery cd. If you have no way to reinstall your operating system, don't wipe the hard drive.
Jun 30, 2009 | Dell Dimension 8250 PC Desktop
Erase a hard drive
IF you have the XP installation CD you can easily do that, Just set your BIOS to boot from the CDrom then put the XP CD on your CD drive then restart the computer , so your computer will automatically boot from the XP installation CD then on that process you will have an option to format the entire hard drive that you have using the XP CD installation, then just let the installation finish...
Oct 16, 2008 | Computers & Internet
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
I am having trouble with the hard drive I think
the first thing that u replace the hard drive right from ur pc to the one u got from ur friend>what happend is ur hard drive is configured for ur mother board>and the mother board of the pc that u got from ur friend is configured for the hard drive so u can not use ur hard drive untill u format it
Oct 14, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
88 people viewed this question
Alun Cox
