Home | PC Laptops | Viao PCG-GRX650 won...
PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Viao PCG-GRX650 won't shut down fully
By DaveBaker on Nov 09, 2007
After I select "shutdown" shut down, it goes through all the normal screens "saving settings" etc. the screen goes dark, the power light, however stays on (the little green light at the base of the unit, to the right of the touchpad). In order to reboot, I have to stick a paper clip in the hard reset button under the unit. After I do that, all the lights go off, then I can press the power button and it starts up.
Curiously, this does not happen when I select "restart" - the machine restarts normally.
Winxp home
P4 1.80 GHz
256 MB of RAM
Thanks!
Solution #1
posted on Nov 10, 2007
Not Rated)
Poohawk
Rank: Wiz
Rating: 84%, 251 votes
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I currently have a Compaq CQ50-139WM laptop. I use CompuHost for doing karaoke shows and the program... (More)
Answer
Hi we need a new laptop can,t decide between a DELL INSPIRON 17 OR HP DV7 3020SA CAN YOU ADVISE... (More)
Answer
uwebcam keepso saying restart or drive found but error in installing it
Answer
ibm t61 turns on but all I get is a blank black screen.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 1447
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
