Question about Konica Minolta DiALTA Di200 Copier
I have an error code -C0070 on a Di351f
Don't have a manual. Bought it used. Hope this is something I can fix or get a part for.
  • 32 Answers
Toner bottle mech is defective.
si
Posted on Jul 04, 2009
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Minolta dialta Di 351f error c0300
no such code in the Di351F service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
Minolta di351f c0070
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner install it correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you mite have a bad motor or the home sensor or acurator for the toner bottle is bad worse case the control board is bad
Nov 05, 2013 | Minolta Di3510f Bizhub Copier
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Panasonic fp7781 error code c0070
Re install toner after shaking it up and reset main power
Oct 13, 2009 | Panasonic Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Hi eerror c0070
Toner moter drive fault. Bottle been put in wrong position. now jammed up machine. remove and turn machine off/on may work. If not have to reset error code in trouble mode. not a problem but engineer needed to do it.
Jan 25, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Konica Minolta DiALTA Di200 Copier Logo
508 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
