My 32'' wharfedale tv does not power after been switch of from main source that is the socket
    Problem Solver:
  • 17 Answers
Check the fuse and power regulator
Posted on Jul 02, 2009
Wharfedale TV power problems
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Televison & Video
BN41-01660B BN94-05068S SAMSUNG UE40D5520RKXXU MAIN BOARD
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 04, 2017 | Samsung Televison & Video
I can't hear the tv i can see the picture
Hello
Either your TVs speaker or its audio output IC has damaged. To confirm which has the troubld, do the following. Place your ears very near to the speaker side of the cabin, and switch ON the tV by its MAINS POWER ON?OFF SWITCH; not by remote control handset. If you can hear a 'thumb' sound from the speaker side of your tV, confirm that the speaker is OK. If so, feed the tV with some extenal audio source; like DVD or CD player to its audio in sockets at its back, play a CD or DVD in the player, select the audio source of your TV to appropriate audio source and listed whether you can hear the sound. If there is sound from this source, make sure that the audio filterins section of your TVs main board has damaged. If there is still no sound from the speakers, make sure that the Audio Output IC of your TV has damaged. OK.
Jul 12, 2011 | Televison & Video
Unplugged tv and when plugged back in doesn't come on
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Apr 11, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Speakers not working
I have a wharfedale 32 HD Ready didital LCD TV and the headphone socket does not seem to work...have used four working headphones that work on Ipods and Hi Fi but they do not work on TV is this a tv fault or do I need a mono small jack on headphone ?
Dec 01, 2009 | Televison & Video
Wharfedale key code
Ur tv is lock could be letters or numbers or anythings.Ask the last owner for the codes.Try unplug it for awhile then replug the power,that all u could do.Codes to reset old tv might not exit anymore.
Oct 22, 2009 | Televison & Video
Tuning my toshiba tv to hdmi
You don't need to tune it to HDMI. Connect the HDMI cable to the rear HDMI socket & then select the HDMI source from the remote control, this will switch the TV to this input & show whatever the picture is from that source ie DVD/Cable etc.
Aug 27, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
