Question about Frigidaire Optional Icemaker Kit
Ice maker is creating layer on freezer floor
Model AD-18 (in a Kenmore) Two problems I believe may be related, FIRST: The fridge has had (for a couple of years) a leak in rear ceiling from some sort of vent that comes from the freezer (a very slow drip, would take a month to fill a shotglass). SECOND: This problem seemed to progress over the course of a few weeks.Stage 1: ice cubes fused together in cube catch drawer toward the back. Stg. 2: larger shield of ice forming inside bottom in rear of catch drawer.Stg. 3:Large icicles forming off bottom of ice maker AND minor flood on kitchen floor. Stg4: Giant ice layer on freezer floor (but no flood on kitchen floor, maybe I caught it before it could develop). The open trough that water flows through (in the hole in the back of the freezer) before it runs down into the ice maker is clear, no ice build up. Hope this is enough detail.
SOURCE: frigidaire ice maker
TRY MAKING THE TEMP COLDER
Posted on Sep 27, 2008
  • 66 Answers
SOURCE: Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Posted on Nov 12, 2008
  • 400 Answers
SOURCE: There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Posted on Mar 11, 2009
  • 254 Answers
SOURCE: Ice maker will not work
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Posted on Apr 01, 2009
  • 531 Answers
SOURCE: ice maker not making ice- water leaking or cubes melting
icemaker have problem
Posted on Apr 06, 2009
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Bought floor model of Kenmore 79737 fridge - it is in display mode (lights on no cooling) kids at store cannot tell me how to switch off manual does not address
My fridge did the same thing. I was told to:
Hold either one of the fridge doors open and press the fridge temp and ultra ice buttons simultaneously for 5 seconds. The temps came on and the fridge started working.
May 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a model 25 side by side. I recently had to move the fridge over a 3/4 in. piece of underlayment bcs. I was replacing the floor. I tipped the fridge up to get it over the 3/4 in. lip. After all...
You appear to have a problem with the defrost components (defrost thermostat and/or heater(s)) located behind the freezer rear panel where all of the ice has built up.
Contact an appliance service company
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Apr 23, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire Optional Icemaker Kit Logo
104 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
