Question about SanDisk Sansa E280 MP3 Player
Sansa 280 with 8 gigs
When I turn my Sansa on it says it needs 6 gb of memory. It started with 8 gb. I use it almost exclusively to listen to recorded books from netlibrary.com that come with a 21 day license. I can get past the opening screen, and was able to activate the fm radio feature, but when I select music it gives me that "more memory" message.
  • Anonymous Mar 25, 2014
    I charge it up but when I turn it on, it won't go past the second screen. Then it won't turn off? It just started doing this unexpectedly"
  • 626 Answers
The message says it needs 6MB of space for the MUSIC DB ( the database, the artist names, etc).
You need to delete some of the recordings off of your device to free up some space.
You can manually delete the files while connected to your computer from My Computer>Device Name (e280)>MUSIC Folder.
Best of Luck.
Posted on Nov 10, 2007
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
I have a 2 gig sansa, and it will only let me use less that 1 gig of space. how can i use the rest?
Plug the sansa into your computer start computer right click e or f or whatever drive and format. This will erase all data on the sansa and put it back to 2 gb.
Hope that helps.
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
One drive is small and full... how do i combine it with the other
you can use a program like Acronis to make an image of the 18 GB drive and copy it to the 280 gb drive, then just remove the 18 GB drive.
You can download acronis from www.download.com
Jan 17, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Error message on E260 player
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Dell optiplex 280 ddr2 memory information
You cannot use drr667 on this computer since it only supportr ddr533, and it will be better if you use one stick of 1GIG RAM since your motherboard supports up to 2 GIG of RAM...
Dec 02, 2008 | Dell OptiPlex GX280 PC Desktop
Not recognizing the memory card
if the micro sd is HC the sansa will not read it because it does not have the right firmware and connection to read an 8 GIG if you want that get a sansa view
Nov 13, 2008 | SanDisk Sansa E280 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa 280 memory
You can format the device thru My Computer. My Computer>Device Name (e280)>Right click and select format. This will erase everything on the device. Best of Luck.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
