Question about Apple iPhone Smartphone
Battery is fully charged, however my iphone just went off and will not go back on
    Problem Solver:
  • 17 Answers
Either virus affected or your battery totally gone to support the phone. try to change the battery first
Posted on Jul 02, 2009
I can't get a full charge that will last on my Iphone 5c
what is your problem exactly. your iphone wont charge fully at what percentage it stop like 90 %.. it may possible that your battery one or two cell not working and that is why it want able to fully change. here is how to do ipad iphone troubleshooting. try to restore iphone to latest version of ios 11. remove your battery then clean connector point of your battery and then reinsert battery.
check your iphone with other battery and then check whether it fully charge or not. also
http://ipodtips-tricks.blogspot.com/2017/09/ipad-iphone-troubleshooting-guide.html
May 21, 2017 | iPhone 5c Cell Phones
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
Am using iPhone 4, the battery was low (not fully drained) suddenly it went off & since that time i cannot switch it on & it doesn't turn on. My phone is almost dead for 2 days now.
1. 1. Connect the Charger and wait for 3-4 hours. After that, try to turn the iphone.
2. If not, try it on another charge Charger or usb port.
3. If all else fails, you need to contact the service for battery replacement or repair.
www.smartjet.mobi
Nov 30, 2010 | Apple iPhone Smartphone
Iphone wont turn on it was on for 10 min then went out. now I cant get it to turn on
Battery is drained. Plug it in and let the thing charge fully for 6 hours.
Feb 03, 2010 | Apple iPhone Smartphone
My blackberry pearl went off and will not come back on. The battery was fully charged
Take the battery out. wait 30 seconds. Put the battery back in, turn it on. Then, consider replacing the blackberry with something that's worth actually owning. (Sorry, im bitter. That last part is my personal recommendation, not technical advice)
Jan 03, 2010 | RIM BlackBerry Pearl 8100
My fully charged 3g Iphone in the Bose Sounddock it keeps poppin
Try putting your iPhone into "Airplaine" mode. It's possible that the radio frequencies from your phone are interfearing with the speakers in your sound dock.
Oct 06, 2009 | Apple Bose SoundDock Series II Digital...
My iphone wont charge..
Had the same problem try rebooting your phone hold the home button and the power button on the top right together at the same time till it completly shuts off and till the apple shows up in your screen... Then let go.. Let it power back up then charge & see what happens... Don't reboot it while it's charging tho... If this don't work it just might be your battery which has gone bad.... Battery last up to 400 charges then after that be best to replace it... Good luck hope this works 4 you...
Aug 22, 2009 | Apple iPhone Smartphone
My Iphone 3g wont hole a charge for any amount of time. I charged it for most of the night last night and it was fully charged at 7 this morning now a 9 it is almost dead
Your battery is deteriorating. Send it in to apple to get it replaced-
$40- 50. when back, fully charge and discharge 5-10 times, and do NOt leave it constantly plugged in.
Jul 15, 2009 | Apple iPhone 3G
IPhone activation
The instruction manual says, "Don?t connect iPhone to the USB port on your keyboard?it does not have enough power." There should be no problem not using the dock.
Aug 07, 2007 | Apple iPhone Smartphone
IPhone Battery power Problems
No, my cousin has one and it works fine, but remember if your battery isnt fully discharged it wont last as long. before you go just charging it all the time you should everynow and then let it run out before you recharge it.
Aug 02, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
42 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
