While cutting my grass the PTO was working fine. The grass was longer than normal and after 30-45min the PTO stopped working. The engine would run but the blades wouldn't engage. Could it be getting to hot or maybe fuses?
SOURCE: Toro Recycler engine doesn't rev up when control arm is engaged
check the throttle spring in the front of the engine.It is hooked to a loop and when going near a bush it will push in and slow the rpms down.If you locate it pull it out and the RPM"s should increase.
