Question about Garden
Homelite back pack blower idles then cuts off when throttle appli
There are two screws to the carb. Both have set screws(plastic collars) that prevent them from turning more than 3/4's of a turn. Should I remove the collars from the screws.
  • 33 Answers
Yes you can,be careful not to bend the screws,then you can adjust the mixture.You do not have to replace the plastic caps but you can.
Posted on Jul 12, 2009
Ryobi C4620 chainsaw idles too fast
I had this same thing . Its in the throttle cable tube. take the cable away from the carb. cut about 1/4 in of the tube around the cable off reattach to carb it works for me!
Apr 23, 2014 | Ryobi DOUBLE D - CARB ADJUSTING TOOL...
How do you get to the throttle jets huskvarna 130BT blower
The 130 has a rotary style carb, so the only adjustment is down through the top of the throttle spindle, you will need a very small flat blade screw driver, the screw down here will lift or raise the needle in the carb, there may well be a plastic plug to remove before you can get deep enough to adjust it.
Dec 27, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
Need to know best way to adjust carb to get maximum performance on my homelite XL12
Regarding the adjustment procedure you generally start your low and high mixture screws at one turn from seat, or slowly turn them in all the way until they bottom out and then back them out one full turn. You will adjust the high speed mixture screw at full throttle and get the median point between too rich (loads up) and too lean (dies out). You will want to do the same thing with the idle mixture screw, just adjust at idle rpm. You will also adjust the low idle mixture screw to give you a smooth transition from idle to throttle up. Once this is obtained, you adjust the third or idle speed screw low enough so the chain does not turn at idle rpm but high enough so the saw doesn't cut off. Hope this gets you going.
Feb 17, 2011 | Homelite Garden
Runs at full speed only cannot adjust carb govenor at full speed
See if there is a Philips-head set screw on top of the carburetor (it is the idle speed adjusting screw) that you can turn counterclockwise backing off the idle (and possibly the wide-open throttle) speed. This is the simplest solution for you unless you wish to remove, disassemble and inspect the carb. Also, check the throttle cable to the carb, make sure it is not hanging up or binding near the engine where it connects onto the throttle plate shaft of the carb.
Sep 06, 2010 | Homelite Garden
Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Apr 17, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Its running too lean..there is a plastic cover over the carb adjustment screws
That may be to keep dirt out. One of the screws should be for the richness setting and the other for the idle speed.
Adjust the richness setting so the tool runs the best (fast) then turn the idle speed down to normal.
Make sure you always keep the air filter cleaned or dirt will get into the carb and cause you to have to clean out the jets in the carb.
Nov 07, 2009 | Homelite Consumer Products Backpack...
Homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Aug 23, 2009 | Homelite 'Yard Broom' Leaf Blower
Engine cut out
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Nov 08, 2008 | Homelite Consumer Products Backpack...
Garden Logo
177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
