Question about Furuno 1715 LCD Radar System GPS Receiver
Furuno 1715 Radar - 'NO HEADING PULSE'
System powers up normal. Screen shows beam rotation, but no definition in azimuth, ie all contacts are complete circles at constant range and caption 'NO HEADING PULSE ' is displayed.
Had similar problem a few months ago, engineer found grub screw holding drive wheel for antenna belt had come loose and scanner was free to drift around erattically. This situation differs as contacts appear as continuous circles of constant range.
Is it likely to be the belt drive again or something more exotic, ie do I get up there myself or go direct to the local agent?
Cheers,
Dave
    Scholar:
  • 111 Answers
More than likely the belt has come off again. This is a common problem with this radar. You'll need a small allen wrench to tighten it up again.
Posted on Jan 22, 2010
Furuno radar 1715
Cek wiring to scanner, change reedswice sensor /heading sensor. If the problem not solve, change the display with the new one.
Oct 01, 2013 | Furuno 1715 LCD Radar System GPS Receiver
Tip
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
on Jan 17, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno 1715 gives "no heading pulse" error. Image normal, but clocked due to no reference. Pulled heading sensor (4X6X1mm black box, two wires, labeled NRS-101) and checked continuity across leads. Open...
Heading pulse is a reed switch sensor built inside the dome. upon each rotation of the array the reed switch is activated. Do a visual inspection of your array (inside) to make sure it is spinning (verify from a distance). Don't get eye level with the rotating array it can cause great harm to your eyes. Normally I have seen the belt slip off and also the lanyard attachment get caught in the array. Check those two things as well.
Mar 06, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Our Radar Furuno 1715-24NM On. ( Power in Oke ) but can not show drawing in monitor/lcd. thanks. regard - damanik
If you have no radar targets, go to longest range 24 miles, gain full, rain and sea minimum, do you have noise, if so, need magnetron, if not, need cable from display to dome.
Feb 07, 2010 | Furuno 1715 LCD Radar System GPS Receiver
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
RE: life of the radar magnetron
i have a furuno 1700 radar ,when i switch it on it goes to stand by ,when i press the standby button you can see it scanning but no land appears cheers alan
Mar 18, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Error message on screen "No heading pulse"
Your belt on the inside of the dome has come off. Take a small allen wrench with you when you go to check on it.
Mar 14, 2009 | Furuno 1715 7" Monochrome Lcd 2.2kw Radar...
Furuno 1623 Radar reading "no heading pulse"
The messages “NO HEADING PULSE” and “NO BEARING PULSE” means that the display is not communicating with the scanner (antenna). Both of these signals are generated in the scanner if you get this error check that the antenna cable is firmly connected and that the contacts are clean and corrosion free.
If the connection at the display looks good and feels like it’s properly connected, check the cable for any damage If you find damage you could try to repair the wires BUT (because of corrosion and moisture problems) IT IS STRONGLY REMENDED that the cable be replaced, but it’s kind of expensive $275.00.
The Part number is 000-130-034. Depending on the marine shops in your area they may have it in stock (or they can order one) but you can get it directly from Furuno at;
http://www.furunousa.com/Furuno/Rooms/Search/ProductPropertySearchResults?_webrFormIdentity=com.webridge.layout.FormLayoutExImpl%5BOID%5B47F81E95CB197F4C8708859EA0E22F08%5D%5D&_webrFormUniqueID=0&_webrCharacterEncoding=iso-8859-1&_webrLocale=en-us&_webrClusterUpload_2=&ptype=com.webridge.entity.Entity%5BOID%5BE670694808555649838ED263AA4CAB0A%5D%5D&productname=000-130-034&searchOption=normal&searchOption_webrHidden=radio
I hope it’s just a loose connection. Good luck!
Apr 28, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1715 LCD Radar System GPS Receiver Logo
749 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
