Question about Canon PowerShot SD1100 IS Digital Camera
Why does the backscreen say busy - Canon PowerShot SD1100 IS Digital Camera
  • marklherman Jul 02, 2009
    What does the hand icon mean on the backscreen? It has a line through it.
    Problem Solver:
  • 17 Answers
It can't read the camera data or memory card
Posted on Jul 02, 2009
I have a lg S530-K laptop after update bios it isn't work. laptop is backscreen .please give me answer how to solve tish problem.
What is this obsession with the BIOS? The BIOS and system registry is like taking a stroll in a minefield, one wrong step and............ If your computer is working properly leave it alone. But hey, that's just me.
Nov 18, 2012 | LG Computers & Internet
Makes a noise when turned on.. sounds like fan or fan motor.
I would make sure the heater is unplugged then remove backscreen and foam filter. Carefully clean firter with warm water and alittle dish soap. Rinse thouroughly and air dry it. I would clean any hair lint or other debris from fan blades,motor and heating elements. You can use a tooth brush to clean heating elements.You can also use a drop or two of light grade machine oil or WD-40 on blower shaft where it enters the motor. Wipe off any excess oil and when you're sure filter is dry reassemble and try it. Hope this helps you.Thanks
Nov 16, 2010 | Pelonis Disc Furnace Heater
I just installed an rlv430 and it works fine, but the backscreen light does not come on. The manual says that it should turn on for 12 seconds when any button is depressed. What could be the problem???....
Hi, the only problem that it could be if the display and system is working good, is a faulty back light from the factory. All you can do is take your receipt and the stat back, and exchange it. It has nothing to do with the way it was wired, its just one of those things that happen from time to time. Even though its new doesn't mean it will work right. I know its a pain, but that is the problem as you have 24 volts there or the unit wouldn't run, and that voltage lights the back light, so its not right.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
PS, please rate me on this post! Thank you!! :)
Oct 03, 2010 | Honeywell Programmable Thermostat Heater
When i take a picture the secrin is black plz
if the picture is being recorded and only the play backscreen is not working then you will have to have the playback screen or associated electronics repaired. If the camera is not even taking pictures or playing back then the camera is broken beyond economical repair. Canon will charge about $125 for a rear screen repair and about $150 or more for a sensor repair. New models better than the one you have start at $299.
Apr 09, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Can not turn off my ipod nano
i have also faced this problem, simply hold the play button for a while unitl the backscreen turns off, then let go and press it again till it turns off.
Nov 12, 2009 | Apple iPod nano
I have a samsung that the screen was pink now, black with sound??
What you describe is a classic symptom of burned out fluorescent tubes in the display. I'm assuming this tv is a LCD model...Unseen by the user, there are long, thin, extremely bright, fluorescent tubes along the edges(usually top and bottom) which light up a backscreen so you have a vivid image to look at. (sort of like how a doctor views xray pictures) As the tubes age, they change color and eventually burn out. An excellent example of the same technology is a laptop display or desktop lcd display--same exact design. Hopefully your unit is under warranty because this is an involved repair *if* it can be done. Most often, the whole lcd display unit must be replaced. Definitely shop around for repair facilities if non-warranty is a factor.
Sep 09, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Dropped Shocked Phone
Thats no shock...Thats the sign of a cracked LCD. To test this, remove and insert the battery and wait for 5 minutes. Then connect your phone to the comupter. Make sure you have Blackbrry Desktop installed on the computer. If your phone is recognized by the computer and you can for example back up your phone, then this means that your phone is fine and you just need a new LCD
May 08, 2009 | RIM BlackBerry Pearl 8100
My archos av700 has a dark screen
Managed to resolve my dark screen issue. It is a little weird and not sure which combination actually got it going but it works. I firstly connected the TV POD unit to the AV700 and used the remote and no joy. With the TV POD unit still connected, I fiddled with the battery latch switch a few times and VOILA! - the screen came back to life and all is now good.
I hope it is as easy as that for all of you....
Apr 26, 2008 | Archos AV700 Digital Media Player
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Canon PowerShot SD1100 IS Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
