Question about Samsung Propel Cell Phone
I accidently swam with my cell phone in my pocket. Everything seems to be fine, but some water got behind my screen. What is the best way to fix this problem, and is it even fixable?
Your gone 2 have 2 take the sim out dry air dry and get a new phone
Posted on Jul 02, 2009
Everything on my iphone works but I can't see anything the view is black
This iphone repair is rated " HARD "
Your phone is water damage and there might be multiple issues. If you can, just open the iphone and try to clean LCD connector. It seems like there is short on LCD connector and it is causing issue. If you clean it with contact cleaner your phone will work 100% fine.
if that does not work then you for sure need iphone screen replacement you can do it yourself or the best is to take to cell phone repair store and get it fixed.
Jan 30, 2013 | Apple iPhone Smartphone
Just got this phone used. Touch screen does not respond. Everything else seems to function
Touch screen phone are too sensitive, common causes are when dropped on the ground,water damage and pressed by inserting it on fitted jeans or pants pocket. once even one portion is not working,they are not repairable, indeed need a replacement.you can ask assistance to any mobile service shop near you.
Jun 27, 2011 | Samsung SGH-A877 Impression Cell Phone
Dropped my droid in water. Removed battery, tried to dry it, and it seemed to work but still had some moisture behind display. Removed battery and let it "bake" for 2 more hours at about 110...
You baked your phone at 110°? That may have fried some of the internal circuitry.
The best way to draw the moisture out of a phone is to place it in a container with some rice overnight.
Jan 29, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
I dropped my Samsung Eternity into water, and the phone worked fine but there was a little water behind the screen. So I just set it out to dry and thought that the sun might dry the water inside and...
The first thing that you should have done is, removed the battery and brought the phone immediately for repairs. Electronics and water dont mix.
there are options, you can replace the lcd and have your phone professionally "dried" using techinician tools.
or there is your option of replacing the phone.
just see which cost less and more practical for you.
hope this helps.
Aug 18, 2010 | Samsung Eternity Cell Phone
LC VX-11000 Dead Outer Touch Screen - Can it be Fixed?
Odds are it may have completely dried out, but left corrosion behind. Replacing the digitizer would not fix the problem, in my opinion. You can buy a used handset for less than $100 online.
The reason I say to replace it is because f you could find someone to replace the digitizer, which the part lists for about $20 online, then you $$ for labor, and it might not fix it, it would be cheaper in the long run to buy another handset.
Again, just my opinion.
Oct 25, 2017 | LG enV Touch VX11000 Cell Phone
Blank screen, cant hear anything on the ear piece!
replace the phone, that is symptomatic of a phone that has a compression crack, (sat down it was in the pocket, shut too tight, etc) There is no repair, but if you have the insurance it is covered as damage.
Aug 20, 2009 | Motorola Mobility RAZR V3
I droped my phone in water and now the touchpad wont work
Did you tried leaving it about a day under the sunlight? If you did try sending it to a store for someone to fix it.
Jul 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Phone was in pocket and got sweaty now the screen is white
The EXACT same thing happens to me if my phone ever gets wet or sweaty! Exept the screens turns grey or black. I take out the battery and let it dry for a couple hours and i'll put it back in and its fine.
:] hope this helps.
isnt it frustrating.??!?!?!
Jul 10, 2009 | Pantech Matrix Cell Phone
Motorazr v3m won't charge...
Usually the batter gets fried when it comes in contact with water (I know because I dove into a pool, swam for 10 minutes, and had my phone in my pocket!).
1. Take the battery out of your phone instantly after water damage.
2. Dry your phone with a blow-dryer until thoroughly dry.
3. Dry the battery.
4. Place the battery back in the phone and press the power button.
5. If the phone turns on, good, if not continue to step 6.
6. Find a friend with a RAZR and use his/her battery in your phone.
If the other battery works purchase a new battery... and by the way... the lines on your screen WILL GO AWAY lol
Jul 22, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Screen broken
You need to take the LCd out and replaced it.
- the flexcable on the phone needs to be replaced.
Jun 09, 2008 | Motorola Mobility RAZR V3
Samsung Propel  Cell Phone Logo
117 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
