Question about VeriFone Omni 3700
No dial tone with 3730
No dial tone error
is there a way to tell if the internal modem is broken?
  • 31 Answers
No dial tone means the terminal is not getting a signal from the phone line.
Troubleshooting:
1) Make sure it is not on a splitter most of time the splitter goes bad.
2) Make sure the phone cord used is a 2 pin cord.
3) Make sure if you have DSL from your phone company plug it in a DSL filter but make sure
you drop the baud rate the terminal uses.
Hit the more key (2nd purple key from left usually the tip key) until you see other setup.
Enter Password Default 1 Alpha Alpha 66831 Alpha key is the little black button above
the number 2.
Then hit the more key again until you see COMMS choose that and hit next until you see
Baud rate. Hit Edit and then NEXT until you get 300 baud when that shows under new hit
select or enter. Choose F4 exit save changes and then the red X key until you are back at
main sales screen Run a test sale.
If still same problem Repeat steps and change baud rate until one works. Usually 300 will
work for DSL lines.
Call me if you need assistance.
www.greenlightpayments.com EXT 105
Posted on Jul 16, 2009
Where do i look to see why machine isn't calling out to verify card
first check the phone line it self. take all phone lines out of the credit card machine, and unplug the power to machine. now take a telephone with a phone line attached and plug that into wall as if you were making a call on that phone. check for dial tone. if you have a dial tone, make a call. do you require a 8 or 9 to dial out? you terminal may not recognize that.
also if you do have dial tone do you use digital or analog phone lines? you need analog for terminals. if you have a fax line you can connect the terminal to fax via phone line. if this does not work contact phone co and ask what type of lines you have, you can also connect most terminals via Ethernet.
Jun 08, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
ATD 66419700 NO DIAL TONE.
That means that the modem cannot detect the correct (or any) dial tone when it picks up the line. Connect a normal; telephone to the line and lift the receiver. If you hear a normal dial tone, then the line is ok. Ithat is the case, then the modem may be faulty. You could try atz command and see what happens. If it is on a pabx or fax machine or something, the dial tone may be non-standard and teh modem won't recognise it. In that case, consult the modem manual for the AT command that tells it to ignore dial tone and dial anyway. You may have to enter that command as well as teh correct command to store that setting, alternatively you can enter the commands as an initialisation string in whatever software you are using to dial.
Hope that helps.
Oct 26, 2010 | D-Link DFM 562E (dfm-562e) Modem
Modem tells me there is no dial tone
Connect the modem to a telephone-jack.
Make sure that the telephone-wire has *FOUR* strands, not just *TWO* strands.
Or, unplug the FAX, and plug a telephone into that telephone-jack, and listen for a dial-tone.
Do you have electronic voice-mail from your telephone company?
If so, does it "beep" a few times when you pickup the handset?
Such "beeps" can confuse any modem that expects *instantly*
to "hear" a dial-tone.
Nov 01, 2009 | Zoom ADSL USB Modem
No Dial Tone
You need to check your modem setting under control panel, there is a "wait for dialtone" option that you need to untick. Please let me know if this fixes the problem.
May 27, 2009 | VeriFone Omni 3700
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
When I try to connect to internet with dial up no dial tone
Here is a link to tell you if your modem is working or not.
http://www.56k.com/inits/a2z.shtml
Not sure what modem you have in your system but this is a link for all the modems.
I hope this helps. Pleasre rate.
Feb 18, 2009 | IBM ThinkPad R31 2656 Notebook
GET "NO DIAL TONE" ERROR.
I must tell you that this is not a printer issue, since printer does not have inbuilt fax capabilities....Actually you are trying to send fax from the computer using a Data Fax Modem. Printer just used for scanning and printing documents for fax...
1. Please check if your computer have Fax modem.
Look at the back of the system tower, if you see a phone jack port (probably two of them).
2. If yes then , you need to have a telephone cable directly from wall (not the ethernet cable coming from DSL modem), fax works on analog signals which is possible only from telehone line.
If your phone line is working, there is no chance the it will give you error again for NO Dial tone
Nov 07, 2008 | Dell 924 All-in-One InkJet Printer
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Retail Supplies Logo
619 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
