hey guys!eve am using d same mobile with same problem!but i think i have explored some thing new!u jus go to the protected message,then to more option,then go for the option send to sim if ur default memory is memory card!then it will get again restart.but the message vanishes!try this,if it works lemme know!
I have noticed the same thing. Occasionally, an email message will display normally in my Thunderbird inbox, but the body of the message will "disappear" when I try to forward it.
My Thunderbird program is set to send messages in plain text format, and that controls the way that messages are forwarded as well (even if they were originally composed in HTML). It works fine most of the time - but a small number of HTML messages "disappear" when forwarded. (I assume there's some problem with the original formatting of the message, or with the way that Thunderbird changes the HTML into plain text.)
I have found a work-around for the problem -- by changing the settings so that messages are sent (and forwarded) in HTML format. Here are the steps: * In Thunderbird, go to: Tools > Account settings * On the left side, scroll to the account in question, then select Composition & Addressing * Then on the right side, place a check mark in Compose messages in HTML format . * Click OK to close the account settings box.
After competing those steps, forwarded messages will retain their original HTML formatting, which should solve the "disappearing" problem.
And of course, you can change the account settings back and forth (between text and HTML composiition) whenever you like. So you could keep your account set to use plain text most of the time; and make the change only when you encounter a problematic HTML message.
Nokia 6303c mobile phone First problem is that Sent text messages sometimes appear in my Inbox. When I delete them another one appears. When I delete they are deleting from the Sent items as well as the Inbox. pls give me the solution for this....
did you take off your memory card? check for settings in messages and try to change the default storage device to memory card, you may get back them, but before this try to backup all you have got
In order to only see the inbox you have to go into your email messages. Then use the BB button and go to options. In Options go to General Options. There you will find the option "Hide sent Messages" Yes/NO
From what I understand, most cell phone companies require a court order requesting release of text messages. Sprint used to let people access them online but they stopped allowing that...w/out the order.
I guess what you mean is how you can import your messages to MSN mail box. You can only import or export your contacts vice versa.
The easy way although quite tedious is to go to your inbox and forward the messages to your email address in your MSN mail.
e.g open your inbox ....... click the message and open it.
click the forward button and type in your MSN email address and click send.
Another quicker way although not tested is to convert your yahoo email to the yahoo classis email. it has better features to forward many messages simultaenously
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
