Computer blocking when a scan has been completed.
I am scanning transparencies with an Agfa Arcus 1200,and after a scan using Photoshop Fotolook 32V3.60.0 Twain,the computer blocks. Do I need a new driver ?
    President:
  • 392 Answers
Check whether u have sufficient RAM , and get ur virtual memory increased..
Posted on Jul 02, 2009
I am having "AGFA ARCUS 1200" Scanner, and want
Hi!
You can use Hamric (VUSCAN) software with new SCSI card. This scanner will work in Windows 7 32 Bit.
I have used it.
Lalit Chawla
New Delhi (INDIA)
lalitc@hotmail.com
May 01, 2011 | Agfa Arcus 1200 Flatbed Scanner
I need the power and connection wire specifications for arcusII agfa scanner.
My Arcus II is 20 years old. I don't know when Agfa stopped servicing their scanners. Mine uses scsi connections and it's connected to Mac G5 OS 9. My driver is Fotosnap. I have the original book and loose leaf.
Feb 10, 2011 | Agfa Arcus II Flatbed Scanner
Scanner agfa
el driver esta en esta pagina:
http://static.agfa.com/digicam_scanner_drivers/scanner/duoscan/index.html
Jun 09, 2008 | Agfa Arcus 1200 Flatbed Scanner
Duo scan for Mac
Hi !
Bad luck...!
We had the same problem...
The original FOTOLOOK-program DOES NOT work on Mac OS 10.4 ...!
Advice: buy VUESCAN (professional-version - USD 79), works great & life-update for program...!
Grtz, H.
Jan 30, 2008 | Agfa DuoScan T1200 Flatbed Scanner
AGFA ARCUS II
unplug it all will have to remove driver then download latest driver form website ok and maby cheak usp port
Jan 30, 2008 | Agfa Arcus II Flatbed Scanner
How to change lamp in AGFA Arcus 2 flatbed scanner?
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Trouble with an older scanner
    I'm assuming this scanner interface is a SCSI connection. First thing you may want to look at is the SCSI ID number switch at the very back end of the scanner. Before changing the SCSI ID switch make sure your scanner is powered down. Repeat steps above when trying different SCSI ID numbers to see which one works with your computer. If you have other SCSI devices connected make sure they are not sharing the same SCSI ID # which will cause a conflict.
    Jun 06, 2007 | Agfa DuoScan Flatbed Scanner
    Computers & Internet Logo
    David Payne
    David Payne
