LG Plasma Monitor has recently developed a screen fault
There is of a vertical bar about 1.5cms wide, top to bottom and nearly in the centre of the screen. The same applies when I play a dvd, so it is not a signal issue. The monitor is 4 years old. Any ideas?
  • poilleyman Jul 03, 2009
    Amazing speed of response and a HUGE thank you!! I am not too bright when it comes to technical matters like this. Do I assume correctly that the "vertical ic" (not sure what this is) and "filter cap" are parts that can only be fitted by Plasma Monitor repairer?
    Problem Solver:
  • 17 Answers
Change vertical ic and filter cap 1micro
Posted on Jul 02, 2009
How do I fix a vertical line on a 50 inch nec plasma monitor
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 28, 2016 | NEC Televison & Video
Fix samsung plasma vertical black bar
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Getting vertical bads on ppm63h3 plasma
There are so many reasons for this fault, and can't point out one specified. If you wish to get more details about this kind of fault with Plasma displays, check this link. There is screen-shots to some faulty screen to plasmas, and details about it. Pull up older posts there.
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 12, 2013 | Samsung PPM63H3 63 in. HDTV-Ready Plasma...
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Toshiba 42wp46p
just repaired one of these with the same fault. at the bottom of the plasma panel you will see a row of ribbon connectors, on the back of the ribbon connectors are some surface mount components. resolder these components on the offending connector, clean the contacts on the ribbon connector and reconnect. unfortunately getting to the connectors is quite a job, so give yourself plenty of time. if this doesn't cure the fault then the poor connection is on the plasma panel which you cannot repair, the only option then would be to replace the panel.
Oct 30, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Fault in Plasma display screen
Depending on the location, it could be the Logic Main Board, or a buffer board
Mar 06, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
