Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I get the clutch off to get to the oil pump
  • 376 Answers
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwain How do I get the clutch off to get to the oil pump - e9f0dfc.jpg
Posted on Jul 02, 2009
Chain not oiling
Remove bar and chain, run the saw to see if its oiling without the bar on.
If still not oiling, remove the clutch, clutch drum and check the plastic thread on the oil worm.
Also check for blockages in the pipe from the oil pump that feeds the bar.
Lastly check the oil pump is actually functioning properly.
Apr 01, 2013 | Husqvarna 450 X-Torq 18" 50.2 cc Chainsaw...
McCullock 7-38 chain lube not working
The oil pump is behind the sprocket and clutch, if you have cleaned out the delivery hole in the bar and still no oil, then you will need to check the pump itself, remove the e clip and washer securing the sprocket, remove the sprocket, the clutch is removed with a pin spanner, there is a genuine tool for this 530031112, you can then jar the clutch off against the compression of the saw ( left hand thread ) there is now just two screws securing the oil pump, the pump has a nylon gear, with a steel gear pressed onto the crank, check the condition of the nylon gear, remove the silver bar pad cover tou can then pull out the pick up/delivery tube, on the end is a filter.
Mar 05, 2013 | Garden
Oil pump on 020 stihl
Remove the side casing,then remove the spark plug and use a piston block to stop the piston rising while you remobe the clutch, once the clutch is off, the drum, bearing and oil work should be removable,along with the 2 plastic crank coveres. Once all this has been taken off you will have access to the oil pump.
Apr 28, 2012 | Stihl 020av 020 Av Chainsaw Oil Pump...
Not pumping oil to chain, bought a new pump and oil pickup but I`m not sure where the oil pump is located and what I have to disassemble to get to it.
Most oil pumps are situated behind the clutch and sprocket, these will need to be removed before you can acsess the old pump, if it has an inboard sprocket you will need to remove the clutch first, these are a left hand thread and just spun onto the crankshaft, they need to be jarred off against the compression of the saw, you may need a special tool if there is no nut on the outside of the clutch, this tool fits most Poulon clutches 530035560, once removed it is a fairly straight forward job to change the pump.
Sep 13, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Stihl 023c Blocked bar oil passageway
hi there
noniesretrea
drain oil tank , remove drum and clutch , remove pump driver and remove pump , blow oil outlet line , and blow oil pickup line as well , clean pickup filter, - check saw bar oil hole as well
reassemble and test
clutch threads are l/h, undo it by locking crankshaft and by turning the clutch to the right while removing
cheers pauly46
dont forget the thumbs rating
Jun 12, 2011 | Garden
Husqvarna chain saw 385 xp chain or bar not getting oil at all
check bar oil holes,
check oil tank pickup filter - should be clear, clean oil tank
remove drum and clutch, check drum and check oil pump driver arms ( could have worn or broken off and drum is not driving it around ,
check the worm part of the pump driver as well ,
remove pump oil pickup lines and outlet lines , check that both lines are clear and that the pump is not all bound up / stiff or damaged if everything else is good
i would replace the pump and reassemble , tighten clutch anti-clockwise ( clockwise to loosen it ) make sure drum cut out engages oil pump driver arms
as a rule if replace pump also replace pump driver , they are matched
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mh=10
slect your year from list and open up
cheers hope it helps
paul
Aug 11, 2010 | Husqvarna Chain Saw 20" Bar
Chain is not getting oil. bar and chain both get hot. everytime i refuel chain oil res. is almost empty. i have cleaned the bar groves and holes...whats my problem...stihl 025 saw
hi sounds like you may have a broken oil pump driver tag on the worm ( this is under the clutch ) and clutch is under drum
slot on drum drives oil pump driver around and the worm turns the pump
make sure oil pick up filter is not blocked and the hose or connection to pump under loop handle is not sucking air instead of oil
if these are ok drum ,and pump worm, pump driver tag are ok then faulty pump is problem
remove clip and washer , remove drum clutch is removed by rotating it clockwise ( it has a left hand thread)
you will need to loc crankshaft so it does not move while you undo it
check pump driver worm for damage and driver tag for broken lug that engages drum , check for loose oil connection from tank to pump inlet ( this is under loop handle / support cradle 0
if need replace oil pump fit a m5 x 0.8 cap screw into the pump and pull it out
note make a note of haw far the pump is pushed down into the cavity
so you can refit it into the same positon
there is a little cut out on the side of the pump you must align 1st before fitting
you may wish your local sthil shop to test and repair if need
can get a little tricky
but give it a whirl if you want
cheers paul hope it helps
Aug 08, 2010 | Garden
Oil pump on the TC 610/99
hi mate the oil pump is located on the left side of the engine and is behind the clutch basket . you need to remove left side case and remove clutch basket and is the second cog from front of engine good luck!
May 15, 2010 | 2000 Husqvarna TE 610
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
146 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
