Question about GE Advantium 120 Convection/Microwave Oven
Interior Light is out
There is no mention on how to change the interior light or where to get replacement parts for this in the instruction manual. HELP can' t watch the food go around!!
  • 3 Answers
We just finished the in-wall repair and thought others may benefit from our experience.
Here is the link:
http://www.rainydaymagazine.com/RDM2009/Home/July/Week2/RDMHomeJul1109.htm#AdvantiumBulbReplacement
Click on any of the images for a larger version.
Sincerely,
RainyDayInterns
Posted on Jul 12, 2009
Thanks for the info on locating a new one.
FYI - it's very difficult to locate the position of the bulb inside the oven! GE cleverly put it underneath a metal plate (left side), behind the plastic grill cover on the top/front of the unit. This means you have to uncrew about 6-8 screws to get to the bulb. THEN, you have to pull it out with a set of needlenose plyers, once you can dislodge it from the very tight space in which it rests (upside down?).
Thanks, GE, for making a simple task something extremely complicated and cost-centric in this day and age. I think the engineer that designed this over should be fired, if not shot at sunset.
I will NEVER buy another GE appliance. It has been my experience that they do not make their parts universal, nor do they make self-repairs practical, or cheap.
Posted on Jul 03, 2009
  • 398 Answers
Its in the upper rear behind a plastic or metal shield. walmart has the bulb
Posted on Jul 02, 2009
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Can you give me instructions on replacing the interior light on a GE Monogram Advantium 120 Micro Wave Oven. thank You
I have not worked on this model:
Normally the way to change the light is to remove the interior access panel OR ... (if no access panel) remove the oven cover to get access to the lamp. Two screws on each side and 6 or 8 on the back side. Lift and tilt and slid the cover from the front interlock seam and set it aside. DON'T TOUCH the silver can you see on the side. Find the lamp, remove and replace and put the cover back on.
Allow 15 minutes to do this job. Get a replacement lamp where appliance parts are sold.
Thanks for your question
Feb 03, 2011 | Microwave Ovens
How do i change the interior light on model JBM17905K-01
You can download GE owner's manuals and installation instructions here. The owner's manual covers it if it's user changeable.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 31, 2010 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior light on JVM1490sh went out. How do I replace it?
It looks like this one was not designed to be replaced by the consumer, so you would have to remove the oven from the wall, take the outer cover off, then replace the "holder assembly" which is a lamp holder, lamp, and lead wires.
It is HOLDER ASM part number WB36X102 drawing "INTERIOR PARTS (2)" reference number 1207.
To remove the oven from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you misplaced yours, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts here.
May 15, 2010 | GE JVM1490 Convection/Microwave Oven
Everything appears to work but turntable and light on interior.
It's probably your bottom door switch. See this helpful file.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 04, 2010 | GE JVM1740DM Microwave Oven
Why would an interior light go out after only 1 yr of min. use???
It depends on the model.
Some have a panel you can remove to change the lights, but others require you to remove the oven from the wall and remove the outer cover.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Jan 29, 2010 | Microwave Ovens
Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Oct 19, 2008 | GE JVM1790 1000 Watts Convection /...
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
MCO160UW interior light
They don't make them to be tampered with, sence it is in warranty, just return it, I'm shure they would more then happy to exchange it.
Bob
Jan 13, 2008 | Magic Chef CMV1000B Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
182 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
